Help HD5G blower rotors shot
highrideford View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote highrideford Quote  Post ReplyReply Direct Link To This Post Topic: Help HD5G blower rotors shot
    Posted: 28 May 2012 at 9:23pm
Nice site here
bought a hd5g with a backhoe for less than scrap price. came with a spare motor but both motors blower rotors are busted from water freezing. was wondering if anyone else has had this problem and wondering if they just got a reman blower or if you can still order the rotors from some place. Have done some searching on just the rotors and im striking out
Thanks
Jeremy
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2012 at 10:16pm
I had the same problem on one HD5B I bought and found one lobe at a place in Duluth MN . I had the address and phone number but when look it up a month or so back it's not the right place now.
 I have a complete 2-71 that I have out of another machine but know nothing about it except when I bought the 2 machines from guy he had the extra engine as said this one lost oil pressure so he replaced it with a generator 2-71
 I want $500 for the full engine . What I paid to have a new head rebuilt for mine.
gemdozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2012 at 11:25am
I have  a new bottom rotor blower  DETROIT 271  and have 2 used complet blower
Post Options Post Options   Thanks (0) Thanks(0)   Quote highrideford Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2012 at 11:44am
thanks for the help. gemdozer has what i need
thanks again. ill keep that in mind Coke.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2012 at 1:17pm
If you install replacement rotors be careful and mindful that they DO NOT, CAN NOT contact one another.  Detroit Blowers run with a narrow but significant clearance rotor to rotor, set with a ribbon gauge and shimming the rotor drive gears, you will need at least those pages out of a 71 series service manual to set them correctly.  This is most often after dirt the cause for blower failures.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2012 at 1:29pm
When I was looking for them the first time , one outfit told me they only sold them in sets and needed both as clearance issues would result if mis-matched  sets were used .
 Outfit I got the one from told me how to set it up (according to book) for the proper clearance and match.
 Lot of information out there but some is not the full story.
q4016lanz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote q4016lanz Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2012 at 8:22pm
15 allis chalmers tractors
9 lanz bulldog tractors
2 water cooled deutz
9 john deeres tractors
14 Aus made orange chamberlains
I spent most of my money on old tractors I wasted the rest
Post Options Post Options   Thanks (0) Thanks(0)   Quote highrideford Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2012 at 8:43pm
thanks for the replies. I have a manual i just need to find some feeler ribbon to set and time the rotors.
jamzis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jamzis Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2014 at 7:38pm
Hi, I just rebuilt my 2-71 Detroit Diesel. Ive been searching for blower rotors for a while but cant find any. Do you know where I can find them? I would GREATLY appreciate it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2014 at 10:32pm
Seems when people plug that drain hole in the bottom of the blower housing - water gets in and there goes a lobe - that is what happened to the HD5B I bought from guy .
 He said engine was locked - no engine was free - the lower blower lobe broke from freezing and locked up blower which made engine seem locked.
Post Options Post Options   Thanks (0) Thanks(0)   Quote highrideford Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2014 at 10:05am
I ended up getting a used blower from gemdozer here on the forum
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2014 at 11:32am
Glad you got the problem solved !
This page was generated in 0.273 seconds.
