WD shift problem
wva1980 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wva1980 Quote  Post ReplyReply Direct Link To This Post Topic: WD shift problem
    Posted: 28 May 2012 at 2:20am
This is a similar problem to what has recently been a WD45 topic.  My transmission was stuck in reverse because the shift lever (WD straight) had become disengaged from the shift rods.  I've taken the lever off and looked at everything.  There is no unusual wear to my untrained eye.  We lined everything up and put it back together.  The shift lever has about 1/4 inch vertical (up/down) movement. The pivot pin doesn't keep the lever from rotating unless the lever is pulled all the way up.  My pivot washer is just a small metal piece, should it be rubber lined?  Is the bottom of the transmission cover wore were the shift lever ball rides?  I have an extra cover that I got off of ebay.  It has the shift rods, but no lever.  I didn't think to try my lever in it.  Should I?  Any and all help is greatly appreciated.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2012 at 9:08am
If the lever rotates it will slide between the notches below. Sounds like it is time to replace the gear shift and rebuild the pivot pin holes with over size pins.  MACK
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2012 at 9:25am
it needs the pin installed corretly with no up -down play [with a new washer and snap ring]
  if play still is there can install some bushings to take up play have repaired many
   1-574-342-4545 for more info
This page was generated in 0.191 seconds.
