8070 PTO swap |
Post Reply ![]() |
Williamsburg ![]() Bronze Level ![]() Joined: 25 Sep 2009 Location: Williamsburg Ia Points: 38 |
![]() ![]() ![]() ![]() ![]() Posted: 23 May 2012 at 6:58am |
I want to swap mt large 1000rpm PTO for a 540/1000 PTO out of a 7040.
Any tips??? I got on AGCO parts and got the parts diagrams for both machines and it looks like i need to remove the PTO clutch down to the actual PTO shaft, correct? Any hints or tricks would be appreciated. Thanks everyone. |
Lynn Marshall ![]() Orange Level Access ![]() ![]() Joined: 13 Sep 2009 Location: Dana, Iowa Points: 2403 |
Changing the PTO can be done like you have described.One thing I would do is use the extra plate in the clutch that the 8070 has.The 7040 uses 4 friction and seperator plates where the 8070 uses 5 and one more wave spring for the added horsepower.Just remove the large snap ring,add the extra parts,and then use the other groove for the snap ring.
Edited by Lynn Marshall - 23 May 2012 at 8:16am |
Thanks for the tip.
Post Reply ![]() |
