WD Resto progress
Mike56073 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike56073 Quote  Post ReplyReply Direct Link To This Post Topic: WD Resto progress
    Posted: 20 May 2012 at 9:14pm
WC7610 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WC7610 Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2012 at 10:58pm
wow, nice job.  I think that is the prettiest carb I've seen!
Thanks
TREVMAN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TREVMAN Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2012 at 11:39pm
What size are your front tires?
Flint23 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Flint23 Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2012 at 12:11am
looks like it's coming along real well Approve, was there anything you didn't take apart? Smile
been there done that, not doing it again...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike56073 Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2012 at 8:38am
   I'll have to take a look at the tire sizes and get back with them, I should know by now what they are but I don't.
     The only thing I didn't take apart on this one was I didn't seperate the finals from the axle housings.  The final drive seals weren't leaking, and the upper bearings in the finals were still good and not rusted up. Since this is going to be a parade queen they should go for a long long time yet.
Larrywdin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larrywdin Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2012 at 12:36am
Some of your pictures helped answer SOME of my questions I had.
I sent you a private message on another though!
THANKS for the post!
Edited by Larrywdin - 22 May 2012 at 12:37am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike56073 Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2012 at 7:10am
  Got a chance to look at the tire sizes, the fronts are 6.00-16, and the rears 13.6-28
Larry in Ill View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry in Ill Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2012 at 7:59am
Great looking tractor!!  Can you do mine next?
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2012 at 8:19am
Great rebuild Mike! I just finished my wd-45 last year. I almost tore down mine as much as yours except I didn't tear down the torque tube and transmission. I also didn't grind and replace everything in my motor like you did. It will be a parade queen for sure!!
Do you worry at all about letting the primer sit unpainted too long and getting the fresh paint to adhere properly? I tried to prime/paint the same or next day because my Martin Seynour specs said to not let the primer sit for more than about 7 days. I'm just curious in case I ever get ambitous enough to try another project that big.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TREVMAN Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2012 at 10:31am
Thanks Mike, I think Im gonna go with 6.50 on the front , Ive got 14.9-26 on the back. Your tractor looks great, Trev.
Bill_MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2012 at 4:56pm
gonna bring it down to Butterfield in August?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike56073 Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2012 at 11:13pm
  Bill, this one belongs to a customer that hired me to do the work, I don't know if he"ll haul it to Butterfield, but he's thinking about Hutchinson if I can get it done in time.
     As far as the primer goes, my epoxy primer says to topcoat within 3 days.  The tractor underneath the cover in the pictures is a 53 wd, and I used the same primer and paint on it back in 2004. I've never had a problem with paint adhering despite the fact that sometimes it's more like 3 months instead of 3 days. I've got 4 tractors so far I've done this way, and they all still look great.
        I've got a few other things I do while painting that the paint reps. would sneer at, but the techniques have been working out here in the "real world" very well.
     By the way, in the pictures the light makes the orange look alot darker than it is, rest assured that it is the correct P.O #1.
This page was generated in 0.192 seconds.
