WD45 hood hardware question
David Gibson (OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Gibson (OH) Quote  Post ReplyReply Direct Link To This Post Topic: WD45 hood hardware question
    Posted: 18 May 2012 at 10:50pm
I took the hood and nose off my WD45 to work on it and it looked like some misc. hardware was used. I am ready to reassemble now and I have a couple questions. #1 the two bolts on the top of the hood that go into the nose were self tapping slotted screws. Was that original or should they be hex head bolts? #2 same question only for the bottom side bolts on the nose (the ones under the WD45 decal )? TIA, Dave
David Gibson
http://www.darkecountysteam.com
1956 WD45
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2012 at 5:15am
On mine, they were 1/4-20 Round head slotted machine screws, same for the side screws.  I am not going to say absolutely for sure it is stock, but I think it is.
Upon strained eye inspection of some factory photos, I can't tell for sure, but it did bring back the thought that they had over sized heads on them, so they didn't need a washer, so the standard round head or PAN head screw of today, won't be right.  I wan't to say the head was near 1/2" wide, maybe even 5/8", but the height was only 3/16" maybe a 1/4"
Edited by Orange Blood - 19 May 2012 at 5:20am
Still in use:
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2012 at 6:46am
They are suposed to be slotted head 5/16 machine screws. they should have nuts welded to the radiator shell.
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Gibson (OH) Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2012 at 8:15am
Thanks. Unfortunately 2 of mine a mangled beyond use and the other 2 I had to grind flat sides and use vise grips to get out.
David Gibson
1956 WD45
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2012 at 1:27pm
I'm a little conflicted as I have one of each?  LOL
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2012 at 7:28pm
  TAKES 2 5/16X1/2 ON TOP     6 FOR BALANCE  3 PER SIDE  3/4 IN LONG
  ORIGINALS USED SQ NUTS ON INSIDE   USED A SCREWDRIVER AND 9/16 OPEN END WRENCH TO REMOVE   MY 2 CENTS
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Gibson (OH) Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2012 at 7:59pm
Thanks Norm. Looks like I'm buying all new then. Mine looked like yours Stan.
David Gibson
1956 WD45
This page was generated in 0.132 seconds.
