HD5 undercarraige
teamgreen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote teamgreen Quote  Post ReplyReply Direct Link To This Post Topic: HD5 undercarraige
    Posted: 15 May 2012 at 7:46pm
Hello all, I bought a HD5G a while back, havent really done much with it until now, Im sort of new around these older track machines and I have a dumb question to ask, where are the grease fittings located on the idler wheels?  thank you in advance for the help.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2012 at 8:20pm
 They do not use grease , they use oil in the rollers and idlers , they use timken cone and cup bearings in all parts . also in the rear axle to truck frame bearing , that one is a link belt spherical roller bearing - 2 part each on inner and outer (4 pcs).
In the center of the axle is a plug / remove this and use a OIL gun with tube to reach inside and then pump oil into cavity until it runs out around fill tube , then re-install the plug . A light semi-grease has been used by some in this area like a #000 0r #0000 fluid grease.
 The outboard axle bearing on early machines was oiled through rifle drilled axle and a few other fittings like steering clutch throw out bearing and flywheel pilot bearing were lubes by felt wick and tub arrangement , most have been converted to gun grease, and in flywheel plugging crank shaft hole and putting in sealed ball bearing for pilot.
Edited by Coke-in-MN - 15 May 2012 at 8:21pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote teamgreen Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2012 at 8:06pm
thankyou very much for the insight, thought I was going nuts not being able to find any grease fittings under that thing.
