WD 45 Brakes
davidk View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote davidk Quote  Post ReplyReply Direct Link To This Post Topic: WD 45 Brakes
    Posted: 13 May 2012 at 8:46pm
How do I get the brake shoes out of the housing after pulling the pin and backing off the stop screw? Do I have to remove all the snap rings and pins on the top part of the shoes?
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2012 at 8:56pm
Been a long time ago but I think I just took the nut off the draw bolt and seperated them there.What ever is was,it wasn't a big chore.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2012 at 9:07pm
To remove brake shoes, remove brake compartment covers. Disconnect
and remove front and rear shoe return springs (1 & 8). From lower
side of transmission housing, remove brake shoe anchor pin lock, and
remove anchor pin (15). In the event that the brake anchor pin cannot be
removed by prying, it may be necessary to drill and tap the anchor pin
so that a suitable puller of the stud and sleeve type may be used. Remove
adjusting nut from clevis (6). Front shoe should be removed first, through
compartment cover opening. Remove rear shoe in like manner.
Reinstall the front shoe, as an assembly made up of the brake shoe,
toggle levers, toggle pin and adjusting clevis and pin. The large brake shoe
return spring (1) is for the rear shoe and the smaller spring (8) is used for
the front shoe.
Post Options Post Options   Thanks (0) Thanks(0)   Quote davidk Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2012 at 9:48pm
Thank you, that's the info I needed. I have the pivot pin out and the springs off and the stop backed off. It still didn't want to come but now I will work harder at it. The brake rod broke off inside the housing so there is a small piece of it still hooked up it may be hanging up. Thanks again...Dave
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2012 at 8:07am
The brake housings are well known for harboring mice thru bad weather and non-use. It may be jammed up with all kinds of nesting material.
Post Options Post Options   Thanks (0) Thanks(0)   Quote davidk Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2012 at 7:58pm
Thank you, there is a pile of mouse nest on the ground, I haven't had a chance to try getting it apart. Maybe tomorrow....Dave
RJM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RJM Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2012 at 6:40am
I have a broken brake rod on y AC wd 45....loooking for some suggestions on replaceing it....
thanks
Bob Miller
dannyraddatz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dannyraddatz Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2012 at 7:10am
Make sure all of the parts on the pivot parts are moving freely. If you don't have a repair manuel for your wd45 you need to set your brake rods at a set length and adjust the brakes one wheel at a time. Use anti-seize on those brake pins when you put the back in. I did my brakes a few months ago, if you need information pm me and I will call you back.
At least your pins didn't have to come out this way. LOL like mine did.
Edited by dannyraddatz - 29 Sep 2012 at 1:17pm
Danny Raddatz
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2012 at 7:28am
Those pivot pins can turn a brake job on one of these into a HUGE job!! One thing about it when done and the brakes work as they should it is very satisfying.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dannyraddatz Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2012 at 8:53am
I could not believe the difference after everything was freed up on how different the brakes worked.
Danny Raddatz
Post Options Post Options   Thanks (0) Thanks(0)   Quote dannyraddatz Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2012 at 9:05am
thanks
Bob Miller
Bob,
Is yours brake rod broken off clean or is part of it hanging out?
Danny
Danny Raddatz
RJM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RJM Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2012 at 1:09pm
It's  broken off and cannot see if any part is inside the housing...I took off the brake cover and cannot see wear the rod attachs to the  drum....
tks
Bob Miller
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2012 at 2:47pm
The 3/8" rod from the brake pedal goes to part 13 (toggle pin) in danny r's posted picture.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dannyraddatz Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2012 at 3:45pm
tks
Bob Miller
Bob,
I would pull the bottom pin out and see if I could wiggle the shoes out, then see if I could soak that part with PB blaster and drill and retap if it would not come out any other way.
Danny
Danny Raddatz
This page was generated in 0.079 seconds.
