first time sickle mower setup on B questions/ help
RockyBottomFarm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RockyBottomFarm Quote  Post ReplyReply Direct Link To This Post Topic: first time sickle mower setup on B questions/ help
    Posted: 11 May 2012 at 7:30am
I plowed our garden a couple weeks ago with my B, last night I went and took it off and put sickle mower on part way.  What do you guys use for the spacers where it mounts to the drawbar? are they like washers or a thick spacer?  my pitman arm is broken, will make a new one this afternoon with a piece of oak. My swath board is missing, anyone have diamentions so i can make a new one as close to origonal as possible?
I have a second sickle mower bought less than an hour away but it is missing alot of parts.
also what size belt do I need?
I also need the S hook for the lift mechanisim and PTO pully
Thanks
38 & 41 B, sickle mower, 2 way plows, rear field cultivator, 2 row drill planter
40 Combine
66 Combine
Roto Baler
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2012 at 9:18am
Lots of questions.  Let's give it a whirl.  First, there were brackets that fit the mower frame to the top of the draw bar.  After that to adjust the belt large flat washers were used.  In some rare cases we put the mower frame below the draw bar to keep the belt tight.  As to the pitman be certain you get a good measurement before you cut another pitman rod.  It is necessary for the blades to be timed so that they move from the center of a guard to another guard so that the hay is cut efficiently.  Swath board is not all that important for measurement, however, there was a dowel that rose up from the board to "flip" the hay.  Perhaps someone has pictures of a swath-board to  show.  Belt I cannot help you with.  Perhaps you can call Sandy Lake, they are most helpful, and get the measurements.  Do you have the pulley for the PTO?
If the S hook - if it is what I am thinking - you may want to get an original from an AGCO dealer cause it lifts a lot and needs to be very strong.
Good Luck!
Bill Long
wjohn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2012 at 9:24am
There's a dimensioned swathboard drawing online. If you google it, it should come up. The PTO pulleys can be kind of expensive when you find them. Do you have a single or double belt model?
Post Options Post Options   Thanks (0) Thanks(0)   Quote RockyBottomFarm Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2012 at 10:02am
yes i need PTO pully , its a single belt.
40 Combine
66 Combine
Roto Baler
Murph-NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Murph-NC Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2012 at 2:16pm
I may have the 'S' hook, I'll check for you.  Sold my pulley on here a few years back.
Here's a link to Rod in NH's page for the swathboard... http://personalpages.tds.net/~thompson_wp/acb/swathboard/swathboard.htm
Edited by Murph-NC - 11 May 2012 at 2:17pm
'41 C w/Woods L503 mower, #3 mower, 2-way plows for C
jjrosty View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jjrosty Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2012 at 2:29pm
the Pulley is a 10" diameter.  last year  i bought an original  replacement for one that "walked" away from my mower.  I then found new replacements at a farm store for 1/2 of what I paid for the original.  this was at Orshlens & would have had to have the hub welded in to the pulley.
MikeinLcoMo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MikeinLcoMo Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2012 at 2:32pm
I think I've still got a couple of NOS pitman sticks around here somewhere.
morton(pa) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote morton(pa) Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2012 at 2:59pm
Your drawbar may sit at an angle. In my case, I have the original "leveling blocks" as I call them, that sit on the drawbar to create a level surface. Once you have the level surface, the mannual calls for 7 (Im pretty sure) washers on either side. The mannaul is floating around online somewhere in PDF format. I lost it when my computer crashed. Like Bill said, you should have something that runs from the fender brackets on down to the drawbar to help support it. The belt needs to be a heavy V belt which should have a part # in the mannual which I believe is still good through AGCO and I forget what diameter the pulley is.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Murph-NC Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2012 at 9:56pm
RockyBottom, I have the S hook.  Shoot me a PM and we'll figure out the details.
Post Options Post Options   Thanks (0) Thanks(0)   Quote RockyBottomFarm Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2012 at 10:52pm
I bought original "setting up directions and repair parts list" book for my mower tonight.  found part # for belt and it says to use several washers for spacers.
still need pto pully
40 Combine
66 Combine
Roto Baler
Post Options Post Options   Thanks (0) Thanks(0)   Quote RockyBottomFarm Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2012 at 8:35am
so there are 2 different part #s in my new book for the belt, neither # is good on agco's site.  anyone have a newer part #
Thanks
40 Combine
66 Combine
Roto Baler
Post Options Post Options   Thanks (0) Thanks(0)   Quote RockyBottomFarm Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2012 at 12:40pm
well I forgot I had home made pully in the shed, its only a 9" though so everything will go slower than if had an original 10",  found a used belt to fit for now.  started to make a pitman arm out of oak.  going to start new swathboard also.  had to take PTO shield off to put pully on..........
anyone have a pic of the rockshaft the use for there sickle mower?  manual shows a different one than the plow.......
still loooking for original PTO pully.........
40 Combine
66 Combine
Roto Baler
OzarkAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote OzarkAC Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2012 at 1:54pm
The belt on my sickle is a Dayco model C51 if that helps.
GlenninPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlenninPA Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2012 at 6:46pm
B hydraulic lift for the mower is the same bundle as for the 60 cultivator hydraulic lift.
Good judgment comes from experience. Experience comes from bad judgment.
From listening comes wisdom and from speaking comes repentance.
Wise men learn more from fools than fools from the wise.
