Mounting tires?????????????
TMiller/NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TMiller/NC Quote  Post ReplyReply Direct Link To This Post Topic: Mounting tires?????????????
    Posted: 09 May 2012 at 4:45pm
Is it easier (better) to mount 11.2 X 24 rear tires on the rim before putting the rim on tractor or after?    Tim
bobkyllo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bobkyllo Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2012 at 4:54pm
put the rim on the tractor the install the tire. you wont be chasing the rim all over. also when done on the tractor you can use the weight of the tire to help you install it.
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2012 at 7:04pm
TexasAllis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TexasAllis Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2012 at 6:45am
It's much easier to mount the tire on the rim if the rim is already on the tractor.
1944 Allis C
1960 Allis D-17 LP
Bob-Maine View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob-Maine Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2012 at 7:12am
I wish I had read this about ten tires ago. But i have had great luck breaking beads by using a 12 ton hydraulic jack. With the tire/rim flat on the floor, put the base of the jack close to the rim edge, using the tractor drawbar to provide a vertical weight for the top of the jack to work against. It's good to hear that noise of the tire bead coming free from the rim. Saves a lot of hammering and swearing. Bob@allisdowmeast
I used to think I was indecisive, but now I'm not sure.
nella(Pa) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nella(Pa) Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2012 at 8:11am
After cleaning and painting the rim I always coat the rim and tire bead with old rancid lard that was used for baking or deep frying doughnuts. I keep it in the shop for wood screws, tires or whatever. It makes mounting easier and prevents the tire from sticking to the fresh dried paint and if you don't paint the rim it makes tire removal easier the next time. You can't put too much on. I always change my 4020 rear tires on the tractor. Take a front end loader and break the bead with the bucket or the skid steer Bobcat. This is the easiest way I have found for the job. If you have liquid in the tire run a pump off of the pto to suck it out and pump it back in.
j.w.freck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote j.w.freck Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2012 at 11:03pm
that little tool in the video clip is pretty nifty.never saw one before.we have had tires repaired on our big tractors on the farms,right out in the field.very fast and back to work in no time...
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2012 at 5:25am
shucks....ya'll ain't lived....til you squirt starting fluid in them tires, them throw a match to make em seat!!   whew!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2012 at 10:23am
DALE, WHERE do you learn some of these things!?
SteveC(NS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveC(NS) Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2012 at 5:00pm
Tim, I gotta say I had a chuckle when i thought to myself "is this guy the owner of miller tire?".
This page was generated in 0.727 seconds.
