Leaky tubeless tire fix
nella(Pa) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nella(Pa) Quote  Post ReplyReply Direct Link To This Post Topic: Leaky tubeless tire fix
    Posted: 09 May 2012 at 12:49am
I had a pesky tubeless wheel barrow and rear lawn mower tire that was always flat every time I wanted to use it. They were those type of leaks that had many little bubbles around the tire when I sprayed soapy water on it. Instead of buying a tube for each I had some remnants of oil base paint in cans that was drying out so I broke the bead and dumped some of the paint in the tire, put air in it and mowed the yard about 5 weeks ago and the tire still is holding air.
  I thought I would pass this along, it is a cheap easy fix.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2012 at 5:36am
If I was going to take the wheel Off and break the beads down, I think I would have a tube standing by ready to install.
Fix it right and be done - not just a Band-Aid fix.
Gary
captaindana View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2012 at 5:56am
Nella I assume PO#2 but in a pinch PO#1.lol   I have the same pesky issues with a jack wheel I installed on my rake tedder!
Post Options Post Options   Thanks (0) Thanks(0)   Quote nella(Pa) Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2012 at 6:59am
Gary
I only break one bead and only far enough to pour the paint in. Trying to seal both beads with the paint in there can be messy. I hope the repair will last a long time because some of the tires you get today are very poor quality along with the tubes. If it don't work the worst will be I will end up with a painted rim and be rid of some spoiling paint.
Post Options Post Options   Thanks (0) Thanks(0)   Quote nella(Pa) Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2012 at 7:14am
What I used was an indoor oilbase wood paint that had some age to it, don't know where it came from, it had about 1/2 to 1" of dried paint on top so it was no good for painting. If it don't work very long I will have to "eat my paint" and let you Allis Men know!!
bobkyllo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bobkyllo Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2012 at 4:41pm
hate to burst your bubble but you may as well consider that tire junk if you put oilbased paint in there. the oil will rot your tire out. it makes it very very soft and eventually it will fall apart. usually if it were me i would spend the little extra time and money and fix it right.
Boogerowen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Boogerowen Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2012 at 7:58pm
Well, boys and girls, this old man is halfway between 70 and 80 yrs, and I have found that it is always better to "do it right the first time" !!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote nella(Pa) Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2012 at 10:25pm
The paint will not rot the tire and make it fall apart, so that will not burst my bubble or tire! If I would have to plug the tire or have to use the check spring that might affect my bubble a little, but it sure beats $20 for a junk Chinese inner tube.
kffischer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kffischer Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2012 at 11:08pm
With a wheelbarrow, you could step up to a 4.80x8 trailer tire for not much more money than the wheelbarrow tire.  you'd never wear it out!
karl f
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2012 at 11:35pm
Good job Nella! i ike your thinking! i also had a leaky wheel barrow tire, i used that spray foam in it, the nozzel fit right down into the valve stem, i just kept squirting it in, and it hasn't gone flat since! use what ya gots!
Post Options Post Options   Thanks (0) Thanks(0)   Quote nella(Pa) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2017 at 7:51am
I would like to give an update on how the oil base paint in the tire worked. The tire lawnmower rear(23x10.50-12) just started leaking like it did before, so it lasted about 5yrs. The paint was old and had a crust on top, I put all of it in the tire which was about 1 1/2 to 2 qts. So I will try it again to see how it works.
Edited by nella(Pa) - 24 Jun 2017 at 7:59am
Stan R View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan R Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2017 at 7:58am
Bought a new wheel barrow rim, tire with tube and fully inflated at Lowe's last week for $21. Would of bought just a tube, but for a few more bucks bought this instead.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2017 at 12:49pm
Any more when I have a leaky small tire, I buy the ones with Slime in them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2017 at 7:43pm
I just recently fix a leaking tire on the 3 point hay rake. Pumped it up some and drilled a hole right thru the middle of the tread, opposite of the valve stem. Then I pulled the core and spray 2 cans of expanding foam in the valve stem. It filled the tube and started coming out the hole. Let the rake set with no weight on the wheel for a day, and I'll never have to touch it again in my lifetime.
 2 cans of foam cost less than a new tube and the tire has enough tread for 30 years of raking.
Edited by CTuckerNWIL - 24 Jun 2017 at 7:44pm
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2017 at 1:13pm
Sure are some interesting tire fixes. I would consider them all if it was WW3 and no tires or tubes available. LOL...
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2017 at 1:29pm
I just installed tubes into the rears of a Cub Cadet(aka MTD) rider as sidewalls were leaky.
There was NO way I could get the tire/rim off the axle, 'rust welded' on , sigh. So, I raised up a side for better access and then broke the outside bead with a 10" C-clamp. It was actually easy to slide the tube in and I remembered to put the valve stem tool on BEFORE pushing the rest of the tube in. Once  all in, inflated to 20PSI in 3 steps, just to allow tube to 'adjust' itself to the tire. That was 4 days ago, still holding air!
One trick I learned with good tubeless tires but bad bead...is to use some spray 'belt dressing' on the rubber bead. I'm 4 for 4 on perfect sealing of the rim.
Jay
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2017 at 5:39pm
This I don't understand, I was in the tire business for 22 years. If you put paint inside a tire, it is all going to run to the bottom of the tire and get hard. When the tire flexes it is going to break up or crack off the tire and turn to eventually turn to dust. As far as putting oil base paint in a tire the guy is right, oil and grease WILL destroy a tire. I've seen it several times with rear tractor tires. Dish soap isn't slick enough to mount most 18.4X34 rear tires. I have seen idiots use grease out of their grease guns for tire lube and then, two years later wonder why the bead on the new tires they put on are soft as putty. Then the tire starts slipping on the rim, rips stems off their tubes, only thing to do is buy another set of tires, get a pro to install them and recycle the old ones. As grand pa said do it right the first time or have someone do it right for you,
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2017 at 7:45pm
Tom do you know of a grease that would not damage tires??? I ask because there is a local tire store that used grease to help seat beads on tubeless tires. For a number of reasons have not used there services in 10 years,so they may not do that anymore.
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2017 at 8:07pm
I've seen rubber cement used. It didn't work. Perhaps if the rim had been power brushed clean first.....
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2017 at 10:21pm
OLF uses tireject....I wonder if it would work on a 4 rib 10-16 front tractor tire I have with stubble damage? Came out of the field last night and it was low, then went plumb flat in less than a minute. Tried airing it up but it was leaking out about as fast as I put it in right along one of the ribs.
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote nella(Pa) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2017 at 8:38am
There are different kind of bases for oil and grease. In the paint I use is linseed oil which is  a vegetable oil and will not attack the tire. After the paint is put in the tire you run the machine and the paint will cover the inside of the tire and work the paint into the very fine sidewall holes. The fix lasted 5 yrs. and didn't rot the tire. I also use old lard for the beads on tubeless tires and and rear tractor tires(18.4x34 JD4020) never spun a tire on the rim yet(over 30 yrs.) and the lard doesn't rot the rubber.
Edited by nella(Pa) - 26 Jun 2017 at 8:43am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2017 at 12:57pm
In the past when I worked at a Good Year shop they had what was called Frey Lube. It's about the consistency of wheel bearing grease. It works great for mounting tires and in the case of aluminum wheels it stops the corrosion from happening. Worked well on rusty steel wheels too.
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2017 at 5:17pm
I'd of junked the wheel barrow and got a trailer to go behind my garden tractor and
RODE while I was doing my haulingLOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2017 at 9:26pm
Ray I do not know of a grease that will not damage tires. They make several brands of paste tire mounting compound, Murpheys is one of them. Anything that has oil or grease in it will destroy tires. I have been out on the road with semi steer tires, out on the road and in the field with tractor and combine tires simply because people used grease or motor oil to mount them. It is a real pain when you have to hook two loaded grain trucks to the back of a darn JD combine that is sitting nose down on a steep hill on a gravel road after dark because some clown used grease to mount the tire. That's a lot of time just to clean off the messey rim, run back to town grab a new 30.5x32 tire and make the trip back, mount it and get them going. That 1 took most of the night. That was only 1 of many. Oh they brought the combine to the shop the next day and we mounted a new tire on the other side. That tire was destroyed too. I have seen the same thing with kids mounting 12x16.5 tires on white spoke rims. They brought the tires to us for adjustment. The dealer where they bought them told them just what they did and could not help them. We couldn't help them either, but did clean up the mess and mount up 4 new mudder's. Dish soap ain't slick enough to mount tires been there tried it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bobkyllo Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2017 at 11:02pm
If you use Dawn dish soap it will dry out the tire. DAwn dish soap will remove​ the oils from the tire. I'm not sure about any.other brands
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2017 at 12:45pm
If for nothing else, you can get Ru Glyde at most auto parts stores.
