hub removal bolts
tomstile View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tomstile Quote  Post ReplyReply Direct Link To This Post Topic: hub removal bolts
    Posted: 08 May 2012 at 7:18am
Does anyone have the dimensions for the hub removal bolts for a D-19? Plan to make a set but want to be accurate. Thanks.
Matt MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt MN Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2012 at 7:37am
Where are you located? I have a set I could sell.
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2012 at 9:13am
ALLIS EXPRESS!
This year:
Kcgrain View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kcgrain Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2012 at 9:19am
If you plan on making a set, you better have a place that can harden these. We have a IR 3/4 1400# of torque air wrench that will snub on some hubs, a regular grade 5 or even 8 bolt that size that IR will twist off, and with all the hubs we have loosened we have yet to damage a Allis Chalmers built hub bolt.
