Engine rebuilding
GeorgeinNJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GeorgeinNJ Quote  Post ReplyReply Direct Link To This Post Topic: Engine rebuilding
    Posted: 06 May 2012 at 10:08pm
When installing new sleeves, what do you guys use to lubricate the "O" rings? I'm rebuilding an allis chalmer RC engine.
Dave in il View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in il Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2012 at 10:23pm
Vasaline, it won't swell the O rings like engine oil does.
AGCO My Allis Gleaner Company
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2012 at 10:49pm
straight Dawn liquid dish soap. "They" claim any petroleum base lube will turn to carbon over time with heat and become abrasive to o-rings as there is always minute working of sleeves in blocks using sleeves. Is it true? I don't know.
chllngr528 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chllngr528 Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2012 at 5:59am
Use what the sleeve/o-ring manufacture tells you to use.
OrangePowerFranzen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote OrangePowerFranzen Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2012 at 6:01am
i have used vegitable oil,
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2012 at 6:12am
I use oil oil; that is olive oil.
Edited by GregLawlerMinn - 07 May 2012 at 4:15pm
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2012 at 7:11am
 Greg -  oil  oil  ??
An Engine Rebuilder told me they use Liquid Hand Soap.
  Gary
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2012 at 7:12am
I also used vegitable oil .
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2012 at 8:29am
Glycerin works great. We also use it to lubricate the syringes in our vet kit.
In expensive and available at any pharmacy.
Hurst View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hurst Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2012 at 8:48am
Veggie oil.
Hurst
1979 Allis Chalmers 7000
5800 Hours
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2012 at 8:54am
Dow Corning 111
DonDittmar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2012 at 8:59am
I too use Veggie Oil or Murphy's Oil Soap
1968 D15D,1962 D19D
Geppy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Geppy Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2012 at 2:29pm
Dawn dish soap is always good, and it won't swell the O-rings or degrade them, it just disolves. But best bet is to go to product website and see what they recomend. Petroleum products are not the best because of the previous reasons mentioned for sure. Good luck and let us all know what you decide to use and what was recomended.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2012 at 2:44pm
I was taught many years ago to use liquid dish soap. Have ever since, and never had any issue. Was also taught to put very thin bead of high quality silicone in the corner of counterbore to help ensure sealing at top of sleeve. Olivers would leak there and leak coolant at sides of head gasket.
LouSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2012 at 2:50pm
my IT manual says hydraulic brake fluid, or thick soap solution. Since brake fluid today may or may not be the same stuff as when that was written, I think I will use "thick soap solution" aka dish soap
I am still confident of this;
Wait for the Lord;
Post Options Post Options   Thanks (0) Thanks(0)   Quote Geppy Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2012 at 3:20pm
I use soap on plug wire boots when I make them up too.
jnicol6600 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jnicol6600 Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2012 at 4:15pm
Crisco is what I was told to use.
Jordan(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jordan(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2012 at 4:29pm
I was told by an old AC mechanic that his son rebuilt a 200 and used oil and it swelled the sleeves enough to seize the engine.
ALLISMAN32 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ALLISMAN32 Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2012 at 8:06pm
We always used castor oil at dads shop. I always assumed that he had picked that up at an allis training school. That castor oil makes those O-rings super slick, the sleeves usually pop right into place when using it. Another thing we always did was before lubing the o-rings, use a small pocket screwdriver or pick and work it around the inside circumference of the o-ring. Purpose being to take any twist out of the o-ring. If you examine the outside of the o-ring you can see the seem, look closely!
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2012 at 9:50am
old suggestions are good but new technology is better.
Industrial Assembly and Maintenance Solutions
News and Upcoming Events
2005.04.19
Dow Corning® 111 Valve Lubricant and Sealant Offers Versatility, Chemical Resistance
MIDLAND, Mich. – April 19, 2005 – Dow Corning® 111 Valve Lubricant and Sealant is a heavy-consistency dimethyl silicone compound that resists a variety of organic and inorganic chemicals.
Dow Corning 111 Valve Lubricant and Sealant can be used as a lubricant for rubber and plastic O-rings, water softener and faucet valves, valve stems for potable water, aircraft vacuum systems, electronic and ignition systems, among others. It can be used as a sealant in applications such as vacuum and pressure systems, equipment subject to washing and harsh environments, electrical service entrances and underground connections, and transformer gaskets and equipment enclosures.
Dow Corning 111 Valve Lubricant and Sealant maintains a serviceable consistency from approximately -70° to 400°F (-57° to 204°C) and has NSF 51, NSF 61 approval and is acceptable as a release agent under FDA 21 CFR 175.300, when used in accordance with that regulation.
For more information about Dow Corning's complete line of high-performance industrial lubricant solutions, contact www.Molykote.com , or e-mail industrial@dowcorning.com.
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2012 at 12:07pm
careful where you put crisco, It's SHORTENING! LOL!
Post Options Post Options   Thanks (0) Thanks(0)   Quote ALLISMAN32 Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2012 at 10:09pm
Pankey, do you just apply the 111 to the o-rings after putting them on the sleeve or should you smear some on the block also? Second question does it firm up like regular silicone or stay in a gell state like dielectric grease? Third and final question can i obtain it from the local parts store, interested in giving it a try if its not too much trouble to find. Thanks alot!!
nella(Pa) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nella(Pa) Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2012 at 12:15am
I was taught by an Allis mechanic to use very heavy water pump grease to lubricate the o rings and take a small round screw driver and put it under the o ring and go around the cylinder a few times to get out any twists in the o ring. He never had one go bad in the past 40 years I seen it used. I always used it on my WD and D17 also.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2012 at 4:02pm
Originally posted by ALLISMAN32 ALLISMAN32 wrote:
<FONT style=": #000000">Pankey, do you just apply the 111 to the o-rings after putting them on the sleeve or should you smear some on the block also? Second question does it firm up like regular silicone or stay in a gell state like dielectric grease? Third and final question can i obtain it from the local parts store, interested in giving it a try if its not too much trouble to find. Thanks alot!!
it stays the consistency.of grease. I just use liberally on the orings.
This page was generated in 0.172 seconds.
