Ca pto lever engage seal
Erik from Wi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Erik from Wi Quote  Post ReplyReply Direct Link To This Post Topic: Ca pto lever engage seal
    Posted: 06 May 2012 at 9:20pm
Trying to rebuild my pto unit on my 53 ca. I have replaced all the seals and gaskets in the housing. I ordered all the parts but that seal in no longer avaiabile through agco. So my dealer sent a washer but it was to small to fit over the 3/4 shaft. I called back and had them sent one that was the right shaft size. Well to say the least it's been almost two weeks and no washer yet . Does anyone know of anything else to use like a rubber flat o ring? I need to get this thing back together so I can mow. The problem is I want to fix it right so I dont have to pull it offf the tractor again to fix.
