C Bent push rod again |
Larry in Ill
Joined: 23 Feb 2012 Location: Central ILL Points: 129 |
Topic: C Bent push rod againPosted: 05 May 2012 at 6:11am |
Good morning all,
I have a question about a bent push rod. The engine was restored a few years ago and after about 50 hours of light use, I notice a ticking and occational pop out of the exhaust. I had a bent push rod and valve. I replaced the valve, guide, and rod and now again I have a bent rod. The valve is fine with no unusual wear. What would be the possible problems? Edited by Larry in Ill - 05 May 2012 at 6:32am |
B26240
Posted: 05 May 2012 at 7:07am |
Are you sure your replacement pushrod was straight? Any slight bend could get worse quickly, also excesive clearance (rocker arm adjustment) posibly could cause it .
MBWisc
Posted: 05 May 2012 at 7:38am |
Or a badly worn rocker arm assembly? Two years after overhaul my B turned into a three cylinder. A push rod had come up along side the rocker. Rocker assembly was worn out. Replaced the assembly and all is well.
