Wd45 plow pictures?
Allis-chalmers wd45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis-chalmers wd45 Quote  Post ReplyReply Direct Link To This Post Topic: Wd45 plow pictures?
    Posted: 30 Apr 2012 at 4:11pm
Hey guys I'd like to see some pictures of everyone's wd45 with plows like 3 bottom sc , 3 bottom semi mount and 4 bottom semi mount. I'm looking into getting one and I am just curious as to what they look like mounted
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2012 at 7:21pm
Here's one of my WD45 pulling a 73/16" semi mount. Don
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2012 at 7:24pm
OOOPS, wrong plowSmile
1954WD45 with 53SC plow
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2012 at 7:30pm
here's one more of it pulling a 53/14" at my plowday two years ago. Don
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2012 at 7:36pm
Here's one more for you. Don
Don(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2012 at 7:54pm
Thanks for posting charlie and don. Don, does the hydraulic tail wheel give you better depth control, compared to just a gauge wheel, or no wheel?
Edited by Don(MI) - 30 Apr 2012 at 7:55pm
Galatians 5:22-24
Roddo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roddo Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2012 at 8:08pm
The tail wheel has nothing to do with depth control.  It just keep the tractor from bearing the entire weight of the plow.  Less prone to wheelies and such when it is raised.  The larger style wheel you see like on my plow was a gauge wheel to set depth.
I don't have a picture handy, but I do have a video!
[TUBE]b86RyuDl5yY[/TUBE]
Edited by Roddo - 30 Apr 2012 at 8:09pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2012 at 8:28pm
Gotcha. Nice video. I knew it help with the counter balance of weight, but thought it might also help with depth.
Galatians 5:22-24
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis-chalmers wd45 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2012 at 9:00pm
Thanks guys! Love to see everyone's wds at work ! I really wanna try to find a semi mount!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis-chalmers wd45 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2012 at 9:02pm
hey don how does she handle that?
HaroldOmaha View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HaroldOmaha Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2012 at 9:48pm
omahagreg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote omahagreg Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2012 at 9:52pm
Our WD with 3-14s
Greg Kroeker
johnny View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote johnny Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2012 at 11:56pm
Here is a pic of me and one of my 45's at the Half Centrury of Progress in Rantoul.  I have a 73 mounted 16" plow.  It did a great job and did not plug up like the others did.
Edited by johnny - 30 Apr 2012 at 11:57pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2012 at 7:23am
In my ground the WD45 will handle the 3 16's just find, I run in 2th gear most of the time it will pull it faster but I don't needd to work the tractor that hard.
Brian F(IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian F(IL) Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2012 at 8:09am
Here's a couple from the Rantoul show of a few years ago.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2012 at 9:17am
Nice looking rig Brian.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian F(IL) Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2012 at 9:50am
Thanks Don,
The plow was originally a semi-mounted plow, but my beaming screw was completely rusted up and would not turn or allow the hitch to flex as it's supposed to.  So, I borrowed a beaming screw from a mounted plow.  As such, my tailwheel is just along for the ride; it looks good but has no purpose as the fixed beaming screw just picks up the whole plow.
I'd like to find a beaming screw for a semi-mounted plow so I could get mine back to original condition.  If anyone has an extra beaming screw for a #73 plow, I'd love to talk to you.  They are not easily found (although I know I've seen a few pictures on here).
Here's my plow before the restoration.  Note the semi-mounted beaming screw.
In. Fred View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote In. Fred Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2012 at 3:36pm
Brain,  My beaming screw was also all frooze up from setting in a woods for 20 plus years. I freed mine up by
heating the female threaded area with a torch and blaster and freed it up
Matt MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt MN Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2012 at 9:02pm
here is my WD with an 80 series 2 botom plow.
This page was generated in 0.031 seconds.
