D-14 engine clutch |
Post Reply ![]() |
mherndon ![]() Bronze Level ![]() Joined: 30 Apr 2012 Location: Tennessee Points: 87 |
![]() ![]() ![]() ![]() ![]() Posted: 30 Apr 2012 at 4:45am |
My clutch just started slipping. I opened the inspection cap at bottom of tractor and thought I found a rats nest. Could this have been clutch debrie? I cleaned it out, and everything was dry. I thought the person i bought it from may have been hiding a leak. I was trying to adjust the clutch, but service book I have is not clear. Please explain how to adjust clutch and is it too late if it has started slipping?
Thanks, ![]() |
D-15, Old dealer in Smithville, TN
MACK ![]() Orange Level ![]() Joined: 17 Nov 2009 Points: 7664 |
If there is free travel in clutch pedal might as well split it. MACK
jaybmiller ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24734 |
When I got my '57 D-14 the entire bell housing was one huge mouse house ! including the area in the starter drive !! arrghh...
Just split it to replace the ringgear. not to bad,well the second time....
Search for 'D-14 clutch' here and you'll get a few great hits or email me and I'll fill you in on the fun you can have.
better to learn from my mistakes than make the same ones yourself !!
Charlie (NC) ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Coastal NC Points: 942 |
when you press the clutch pedal how far does it move before you feel resistance from the pressure plate springs?
Probably 1.5 to 2".
Just got a price of $275.00 from local parts store for clutch, pressure plate, & throw out bearing. All this to just pickup, no shipping. Have not checked online, but shipping would be high I suspect. Is that competitive? With getting my flywheel turned, should this get me going?
Tracy Martin TN ![]() Orange Level Access ![]() Joined: 11 Sep 2009 Location: Gallatin,TN Points: 10824 |
When you look up thru the inspection hole in bottom of torque tube, how far are fingers from throwout bearing with clutch pedal retracted? Tracy Martin
Is it better with sealed or greasable bearings?
I am not at the tractor now. 125 miles away in Jamestown.
I like the greasable bearing. About 35 dollars from Motion Industries. One without it is about 20 dollars if I remember correctly. HTH Tracy Martin
Post Reply ![]() |
