IB QUESTIONS
1946WP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1946WP Quote  Post ReplyReply Direct Link To This Post Topic: IB QUESTIONS
    Posted: 29 Apr 2012 at 10:31pm
COULD ANYBODY TELL ME EXACTLY WHERE & HOW THE BATTERY BOX IS MOUNTED ON AN IB. GOT A NEW ONE , BUT NO HOLES SEEM TO MATCH UP ON THE FENDER. MINE NEVER HAD A BOX ON IT.
ALSO I MIGHT NEED PART # 219940 BELLCRANK ASSY, ACCELERATOR ( INC SHAFT)' I MISPLACED MINE & DON'T KNOW IF I'LL FIND IT. OR IF SOMEBODY HAS THE MEASUREMENT OF IT , I COULD PROBABLY MAKE ONE.THANKS FOR ANY HELP.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2012 at 5:24am
Here are some pictures of an IB Restoration I found.
Shows Battery Box hanging from R/H Frame / Rail.
Gary
bigallis1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigallis1 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2012 at 5:53am
Bruce, you may have to try and find an IB that still has the battery mounted on the left  fender and measure everything up.
Someone else on here might chime in with dimensions and info on the other parts you need.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2012 at 6:31am
From the reseach I've done when I was restoring my IB was that the Battery box could have been mounted in numerous area's. The stock location was the left rear fender where you could whack yer' kneecap workin' the clutch. Some IB's were equipped with sickle bar mowers, and with other attachments, so it varied where the box was mounted. Mine was on the right frame rail like in the pic, so that's where I installed the new box. Mine also had an office chair for a seat also, and ya don't see that to often. That musta' been a rare option.....  LOL!  LOL
Matt MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt MN Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2012 at 8:12am
Bruce,
I am currently working on my IB at the moment, there is a flat steel bracket that mounts between the left fender and the frame rail that the battery box mounts to, I used a battery box for a WC and drilled 1 hole to match up with the holes in the plate, I may have an extra bellcrank laying around if it didn't get thrown away yet.
Let me know if you need any pictures of anything.
Here is a picture that shows the plate, Mine had the wrong battery box on it when I bought it.
Edited by Matt MN - 30 Apr 2012 at 8:20am
