will this work?
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Topic: will this work?
    Posted: 29 Apr 2012 at 10:21pm
I kind of touched on this idea once before with no real for certain response, but will a power shift transmission out of an 8050 go into a 7580, semi feasibly? I do know that anything is possible with enough time and money throwed at it, but I am mostly wondering about the basic bolt up. I know that shifting cables and such would be an issue, which I think could be resolved by raiding a 2wd 7000 series powershift, but other than that would dimensions and bolt patterns be the same? As far as it holding up to the load, I wouldn't worry about that, because the only thing it would be doing is either pulling a planter or a sprayer, neither of which would work it hard, but a power shift would be nice for. Reason I ask, is I have a 7580 with the transmission out of it and a burned up 8050 that the power shift should be all right yet. Any thoughts? Thanks, Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2012 at 10:18pm
bump
Sam T-Ga View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sam T-Ga Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2012 at 11:15am
 it will bolt in, the transmission housings had same bolt patterns , linkage will need to be worked out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2012 at 4:17pm
Thanks Sam
Dave in il View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in il Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2012 at 5:27pm
If you get that puppy together make post about it, and take pictures while your at it please.
AGCO My Allis Gleaner Company
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2012 at 9:39pm
It'll have to be next winter's project. If it works out, it should be a sweet spraying tractor. Darrel
