Cylinder rebuild tool
KRAKMT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KRAKMT Quote  Post ReplyReply Direct Link To This Post Topic: Cylinder rebuild tool
    Posted: 29 Apr 2012 at 1:07pm
Does anyone have a design for making a spanner wrench for removing the end nut from the cylinders of a 715 b backhoe?
These are the lifts that need some new guts- the ends have three notches-
Can weld something up but wondering if someone has perfected a design and would like to share...
Edited by KRAKMT - 29 Apr 2012 at 1:08pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2012 at 2:18pm
I used a 36" pipe wrench .
My lift cylinders have been no problem but the hoe cylinders I have had to replace one piston and one of the end seal glands. The gland or part under that locking ring i got from Minnpar but the piston i made out of aluminum to match the cast iron one that had worn and chipped area.
jnicol6600 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jnicol6600 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2012 at 7:37pm
I used to use a big punch and a BFH on logging equipment.
wfmurray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wfmurray Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2012 at 6:22am
Strap wrench or chain wrench would do less damage to cyl.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2012 at 9:16am
Cast Iron cap with internal threads , locks the gland into cylinder , is just a end-cap and has no other purpose . Needs to be tight to hold the gland but does not seal or hold pressure or act on shaft .
This page was generated in 0.189 seconds.
