Need Help-D-21 hydralic pump
b170dr View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote b170dr Quote  Post ReplyReply Direct Link To This Post Topic: Need Help-D-21 hydralic pump
    Posted: 28 Apr 2012 at 5:56pm
The bottom driven gear with the spines. Gear 11/16 wide. Is it the same gear as  190. The gear that it splins into has same parts  number as 190.  But the bottom driven gear has a differnt parts number. I need the  driven gear. If anyone can help, would sure appriate.  Thank you, Roger
'64 B-10, '58 D-14, '60 D-15D, '58 D-17D, D-19, 170, 2-185D, 190, 68 D-21 11, 72-220, 7000,7030, F-2 G,w/5 Heads,L-2 G, 330 No-Till
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2012 at 7:42pm
Not sure I understand your description. If this is a triple section pump (3-point hitch and Traction Booster) the front pump gears top and bottom (lifting section) are different (wider) than a 190. The middle section gears top and bottom (traction booster section) are the same as a 190. The rear section top and bottom (power steering section) are the same as a 190.
