CA popping out of 2nd gear
ACEd2010 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACEd2010 Quote  Post ReplyReply Direct Link To This Post Topic: CA popping out of 2nd gear
    Posted: 28 Apr 2012 at 4:02pm
OK - just picked up a 51 CA Thompson High Crop. s/n CA7272. Not running yet, but supposedly had problem popping out of second gear - reason it was parked. What am I looking at as most likely cause / repair? best, Ed
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2012 at 6:27pm
It is unusual for a CA to pop out of Second Gear.  Usually it is third.
The usual cause of this is the lugs are rounded on your shifter gear in the transmission.
Sometimes you can fix it with gear shift forks but usually it is the costly gear and shifter replacement in the transmission.
Usually comes from shifting on the go.  Grinds the ears on the gears.
Remember, the CA has a constant mesh helical gear transmission.  That means that you do not shift gears only shifter collars that mesh with lugs on the various gears.
Hope it is not all that bad.
Good Luck!
Bill Long
ps:  CA is a NEAT tractor - yours is a High Clearance CA.  Cool!
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2012 at 7:25pm
Good ol Bill is right on !!
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2012 at 7:32pm
While you have it apart, make sure the thrust washers contain the end play in the gear stack and make sure your shifter is up to par. Any added slop or end play can assist in hurrying the popping out process again, but it is usually caused by grinding gears.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2012 at 10:25pm
We used to have various size snap rings that took up the end play in the gear train.  They were measured in thousands of an inch.  When it first occurred we used them with some success cause it was a lot less costly than dissembling the transmission.
However, you are looking at a tractor that is pushing 60 years old.  I hate to mention the expensive job but if you are going in replace the gears.
Perhaps you can find a used CA transmission or gears.  Check e-bay.  They have the damnedest things at a relatively good price.
Good Luck!
Bill Long
This page was generated in 0.048 seconds.
