6060 Vibration??? |
Mark D.
Silver Level Access
Topic: 6060 Vibration???Posted: 26 Apr 2012 at 4:32pm |
Our 6060 has developed a vibration between the rpms of 1800 - 2100 with nothing noticable before or after. Any ideas of what that might be? Harmonic balancer or looking at rod bearing issue???
Thanks!
Miss Behavin - D21 Super Farm
Xcessive Tinkering - 190 XT Hot Farm Puller Watch on YouTube - http://www.youtube.com/watch?v=J2TX1Af7aoA |
ky wonder
Joined: 13 Apr 2011 Location: horse cave, ky Points: 647 |
Posted: 26 Apr 2012 at 4:35pm |
are you sure the pto is disengaged
i like old tractors of all colors
injpumpEd
Joined: 13 Sep 2009 Location: Walnut IL Points: 5204 |
Posted: 26 Apr 2012 at 6:38pm |
don't those 433 engines use a counterbalance device under the crank?
DrAllis
Posted: 26 Apr 2012 at 7:31pm |
I don't know how bad this vibration is, but they (6060-6070-6080) are a bit prone to this, especially if they have a factory installed cab on them. The clutch mechanism can get out of balance from wear. It is very heavy and hangs a mile rearward from the back of the crankshaft flange. The slightest imbalance can sent a vibration thru the steering wheel, etc. It just simply might be the way it is. They are hard to keep in perfect balance and some of that depends on how particular the operator is.
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8981 |
Posted: 26 Apr 2012 at 11:15pm |
2 balance shafts Ed driven off the rear of crank
Amos
Posted: 27 Apr 2012 at 12:16am |
Mine did that for as long as I can remember, since new. Overhauled it last winter. When I read the manual on how to time the counterbalance assembly it came up with the timing dots either way from perfectly lined up. I did not pay attention when I took it apart so put it on the one way I thought might be closest to perfectly aligned more than the other. Whether this has anything to do with the vibration going away I have no idea, but it is the only thing I can think of that would have caused it as I only inframed the engine.
DougG
Posted: 27 Apr 2012 at 8:38pm |
Wouldnt that clutch outa balance be hard on the bearings in the engine? ?
Mark D.
Silver Level Access
Posted: 29 Apr 2012 at 4:56am |
We did just get a new clutch put in this winter along with some PTO work.
Am I hearing you guys right, the clutch could be not timed with the balancer and that is what causing the vibration? I have never heard of timing the two together on any other tractor. Actually thought that they only fit one way.
DrAllis
Posted: 29 Apr 2012 at 6:45am |
There is no timing from clutch to balancer. It sounds like it is clutch assembly related and that is sometimes difficult if not impossible to cure. You can waste a lot of time and money trying to correct something that just simply might be the way it is going to be. I'm not there driving it, but I'd bet if I put my 83 yr old Dad behind the wheel, he'd never notice a thing. My wife wouldn't either. A keen "gear-head" does notice things like this and becomes concerned. I'm guessing that when you actually drive the tractor in motion at these engine speeds you don't notice it nearly as much. Might just have to live with it.
