d-15 front weights
coastga View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote coastga Quote  Post ReplyReply Direct Link To This Post Topic: d-15 front weights
    Posted: 26 Apr 2012 at 11:38am
I have a D-15 series II gas that I would like to install some front weights. What do I need to purchase to install the weights? I beleive I would need some type of bracket,  and maybe a rod along with the weights.
Also, where is th best (least expensive) place to purchase these parts? I want to keep my tractor original.
Steve
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2012 at 11:49am
There was just a listing of 4 slab weights in Iowa for $350 but they were gone right away. You can buy reproduction slab weights. The only other "correct" weights would be the doughnut weights for the front wheels.
repro weights: http://www.steinertractor.com/ACS180-front-weight
This page also has the weight bracket needed and the rods needed. Gonna have a good chunk of change involved here for "original" look.
Edited by CTuckerNWIL - 26 Apr 2012 at 11:53am
Post Options Post Options   Thanks (0) Thanks(0)   Quote coastga Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2012 at 12:19pm
What else do I need besides the weights?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2012 at 3:31pm
The weight bracket kit and 2 anchor rods.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2012 at 4:40pm
      Probably lots of Cash to buy them when you find them !
     Gary
Lester View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lester Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2012 at 6:10pm
They also had inside halves wheel weights too.
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2012 at 8:11pm
  we have the frt weight bracket   can ship    1-574-342-4545  visa-master cards-
   discover
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2012 at 10:27pm
Deep pockets!  Hard to find, VERY expensive when you do find them.
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2012 at 10:49pm
Best to buy them with the tractor!
Edited by Eldon (WA) - 26 Apr 2012 at 10:50pm
ALLIS EXPRESS!
This year:
houchens View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote houchens Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2012 at 10:53pm
I've got the front wheel weights on mine, they really help.
If you're needing alot of extra weight, try putting a tube in the front tires and filling them with fluid! That'll add alot of weight, probably more than my wheel weights would.
Good luck.
8050 200 7010 185x2 D17-IV D15IIx2 D14 WD45 Deutz Allis 6260 Gleaner Kx2 Gleaner K2 Diesel 2300 discx2 600 and 333 planters 2 AC wagons several AC plows/chisels Rotobalerx2 Other Misc AC Equipment
1953CA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1953CA Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2012 at 10:53pm
I agree with Eldon, alot cheaper route!!!
1945 AllisCletrac / 1948 "B" / 1953 "CA" / 1955 "WD-45" / 1963 "D-15 Series II"
"No Air Support without Ground Support"
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2012 at 11:00pm
1953 CA, it looks like your air cleaner end cap is sitting on the distributor and governor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1953CA Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2012 at 11:47pm
Yup, I was cleaning the filter...
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2012 at 8:17am
Not hard to find at all. Just go to the Stiener web page and order them.Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote coastga Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2012 at 8:42am
Just in case I can find originals, What years and models are the weights interchangable with the D-15 series II?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2012 at 8:48am
The slab weights are all the same.
The mounting is different from one tractor to another and the mounts are on the Stiener site.
MBWisc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MBWisc Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2012 at 9:01am
Looks good but it makes it kind of hard to check the power steering fluid.
