8010 Hard Shifting |
Post Reply ![]() |
Dave in Oregon ![]() Bronze Level ![]() Joined: 13 Sep 2009 Location: Oregon Points: 39 |
![]() ![]() ![]() ![]() ![]() Posted: 25 Apr 2012 at 9:50am |
On my 8010 with power shift, the range shift Hi-Low is extremely hard to shift most of the time. I took the cable loose from the shift lever on transmission to see if the cable then moved free. It moved extremely easily. My question is, could it still be the cable binding when under load? Or could it be something else?
Any help appreciated. Thanks, Dave |
ryan(IN) ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Bluffton,IN Points: 781 |
Have you ever replaced to cable? when they get old they are hard to shift. Replace it and you should be good.
ryan
1984 8070 FWA,1979 7060,1975 7040,1971 190,1960 D-17D,1957 D-14, 196? D-19G, 1975 5040,1971? 160,1994 R62 |
427435 ![]() Orange Level ![]() Joined: 18 Nov 2010 Location: SE Minnesota Points: 18637 |
When you are in gear, is there any sign of creeping??? A slightly warped PD or main clutch would cause hard shifting.
Mark
B10 Allis, 917 Allis, 7116 Simplicity, 7790 Simplicity Diesel, GTH-L Simplicity Ignorance is curable-----stupidity is not. |
pump grump ![]() Bronze Level Access ![]() Joined: 11 Mar 2012 Location: dayton oregon Points: 28 |
Hi Dave, you get your trees out yet ?? Or too much rain ?
Lynn Marshall ![]() Orange Level Access ![]() ![]() Joined: 13 Sep 2009 Location: Dana, Iowa Points: 2379 |
Most often,it's the cable.The 8000 series was introduced in 1982,that's 30 years ago.Time has a way of wearing on things like that.You might check how it shifts when it's running,or when it' shut off.If no difference,then I would certainly suspect the cable.
jiminnd ![]() Orange Level ![]() Joined: 16 Sep 2009 Location: Rutland ND Points: 2296 |
I have found on my 8030 there is a little drag, if I shift to reverse the range shift is easier, not the handiest thing but it solves my problem of hard range shift.
MI8050 ![]() Orange Level ![]() Joined: 08 Oct 2009 Location: West Central MI Points: 226 |
I do this too, mine has the forward creep to it, a quick reverse shift then back to neutral will make an easy shift to high, low, or park.
Post Reply ![]() |
