Washing the wd45
Allis-chalmers wd45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis-chalmers wd45 Quote  Post ReplyReply Direct Link To This Post Topic: Washing the wd45
    Posted: 24 Apr 2012 at 8:35pm
Hey guys my wd45 is so dirty and gunked up I was wondering I could pressure wash it an what to watch out for?
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2012 at 8:47pm
Check the boot on the trans shifter so you don't get water in trans.  May be stay away from dist cap & coil.
Bill_MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2012 at 4:00pm
Whenever I wash my WD I take the plug wires off and ball them up and put a plastic sack over the whole distributor-coil-governor assembly and put a rubber band around the bag behind the mounting flange for the diistributor drive housing. I also put a bag up over the carb as best I can and put a tin can on the exhaust if no rain cap. Might want to avoid direct spray on the dash and battery area as I had some corrosion issues in the ammeter gauge and some wiring. Just wipe clean those areas when you are done.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis-chalmers wd45 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2012 at 9:16pm
Thanks guys always very helpfull!!
ACscott View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACscott Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2012 at 9:38pm
These tractors sit out in the rain and weather all the time. Just don't hold the gun or wand right over the parts for a long time such as the parts listed above and you will be alright.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis-chalmers wd45 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2012 at 10:00pm
Okay thanks!
