bought a plow from zabels auction.
ironac View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ironac Quote  Post ReplyReply Direct Link To This Post Topic: bought a plow from zabels auction.
    Posted: 22 Apr 2012 at 2:09am
think she will look good behind the d17 at state fair this year? what model is this?
Dave (Mid-MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (Mid-MI) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2012 at 5:29am
Model 74 plow with tailwheel. The coverboards look like cultivator weed controllers. Should look good behind a D-17. Does your D-17 have a transport valve for the remote cylinder?
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2012 at 6:42am
She's gonna be grunting a 3 botttom was all my grandfather's 17 wanted.  We run our 4-16 behind the 7060.
cornbinder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cornbinder Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2012 at 7:53am
4-16 behind a 7060!!LOL  you could add  a 2nd 4-16 behind a 7060.
CTD03 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTD03 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2012 at 9:39am
d17 will do just fine with iot. Read up and learn how to set the plows up and the d17 should move it
Dave in il View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in il Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2012 at 9:44am
As I'm often reminded on this sight, "Where your at determines what you can pull"
I used to pull 6-16's with my 7060 and we pulled 5-16's with our XT. Other people would pull a bottom less or a bottom more depends on the soil.
Some people talk about pulling 4 bottoms with a WD45 we can only pull 3 (if it's a SC) and others can only pull 2.
Edited by Dave in il - 22 Apr 2012 at 9:45am
AGCO My Allis Gleaner Company
Don M SEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don M SEIA Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2012 at 11:10am
It will look good at the State Fair.   We plowed alot of land with a 4-14 # 74 just like that with 3 different D-17s in some very tough black gumbo we used 361 bottoms  less curve  than the ones in the picture.  The moldboards shape can make more difference than the number of bottoms, depending on the soil type. Don
NICKMI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NICKMI Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2012 at 11:50am
What's one worth I have one similar only it doesn't have Guage wheel and is missing the cyl what kind of cyl do these plows require thanks
Edited by NICKMI - 22 Apr 2012 at 11:52am
Post Options Post Options   Thanks (0) Thanks(0)   Quote ironac Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2012 at 12:02pm
Yep it has the transports valve. The way I look at it is my 4500lb d14 pulled 3-16s in good Iowa black sod so Im figuring the d17 can handle another bottom.
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2012 at 4:04pm
   we used a 4-16 semi mount with tail wheelin 2nd gear-hi side was ok for us in 0ur sil wth the stones involed  any faster you repairing the equip from the stones   2-16 behind the D-14  SAME WAY   WHEN I WAS A KID NEIGHBOR HAD 17 PILES OF STONES ON 40 ACRES  NEIGHBORS WOULD HAUL STONE FOR CEMENTING CORNER POSTS
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2012 at 7:48pm
I will admit 4-16 behind a 7060 is a bit of overkill.  The plow was bought when the 7000 was the big tractor of the fleet and now we have a retired gentleman that drives for us and he really doesn't relish the 7000 so he plows with the 7060 and since he plows better than us younger pups all are happy.  We only plow a small portion of our ground but if we plowed more we would get an onland plow for the FW-30.
