hd6g clutch info
dav68camaro View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dav68camaro Quote  Post ReplyReply Direct Link To This Post Topic: hd6g clutch info
    Posted: 20 Apr 2012 at 7:13pm
Hi all new here.
I recently purchased ahd6g loader and have a few things to do before I put it to work.
left side steer clutch is slipping have pulled it out already. I need the specs for the bimetallic discs min max, clutch spring height, clutch pack min max height.
Also looking for someone to reline the brake as its the 4" band
Its a later sn unit so it has the bigger brakes and metallic clutch discs.
I am also looking into building a brush cab for this as I have a lot of timber toclear if anyone has pictures or plans for I am in the design stages and looking for ideas.
The last thing I am looking for is a service manual for it in digital format.
Thanks for the help in advance and sorry for the choppy format but I can only post from my phone currently keep getting errors when I post from the PC.
David
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2012 at 7:43pm
You have a PM .
Post Options Post Options   Thanks (0) Thanks(0)   Quote dav68camaro Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2012 at 12:27pm
Thanks for the help coke I am putting the new clutches back in .today the pack is assembled and ready to drop in.
I am still researching the brush cab and trying to find some scrap to build it out of. I ended up relining the brakes my self and it was rather easy. I used rivets and jb weld after talking to several people who had success using this method. Time will tell.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2012 at 1:10pm
I just riveted the linings onto old bands , no filler or glue used . Did paint the metal band with glyptol  to prevent rust.
chow717 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chow717 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2012 at 9:18am
Here is a pic of my loader with cage.
michale34 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote michale34 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2012 at 3:17pm
that a good looking 6g.  thats sure some mean looking teeth!!
gemdozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2012 at 3:44pm
Nice machine and check your final drive oil level he is leaking.
GolfProAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GolfProAC Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2012 at 6:41am
hello
This page was generated in 0.234 seconds.
