WD: Should I buy this?
AllisFreak MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisFreak MN Quote  Post ReplyReply Direct Link To This Post Topic: WD: Should I buy this?
    Posted: 19 Apr 2012 at 8:47pm
Hi all. I can pick up a WD with an A-C rear mounted digger and a A-C 3 bottom plow for $900. The tractor is bordering on becoming a parts donor, has some issues. I have no real use for this tractor, should I pass on it or buy it?
EPALLIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EPALLIS Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2012 at 8:49pm
Whenever you save A-C equipment from the melting pots of China, you are a saint.  Better buy it and save a part of agriculture heritage.  Going orange is going great!
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2012 at 8:55pm
Buy it.
Ian View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ian Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2012 at 6:54am
For 900 with some implements could you go wrong? I just paid $300 for a 3bottom snap coupler plow, I'm not sure what the diggers worth but I'm sure there's enough parts to make you more than your money back.
1980 AC 616
1958 AC D14
1960 AC D14
1987 Cub 1204
1982 Cub 682
1974 Cub 154 Lo-Boy (SOLD)
Hauler: 1998 Dodge Ram2500 Cummins
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2012 at 7:16am
Ian said it right -- even if plow needs work still should bring $250, buy it and leave tractor sit for a while you will be amazed how they grow on a person!
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisFreak MN Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2012 at 10:29am
Bought it. Thanks for the advice.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisChalmers37 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2012 at 12:58pm
If that isn't the whole truth I don't know what is??
wjohn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2012 at 6:13pm
Pictures???
This page was generated in 0.079 seconds.
