Regrinding camshaft for wd45 |
Post Reply |
wrightk20
Bronze Level Joined: 04 Jul 2010 Location: wisconsin Points: 52 |
Posted: 19 Apr 2012 at 10:41am |
I'm in the process of getting parts lined up to build the motor for my wd. It will be build with a wd45 crankshaft. I'm not sure on the liner kit yet, whether to go with a d-17 liner kit or go with an original wd 45 kit. I'm thinking about sending in a camshaft to have reground. Have any of you done this, and has anyone had them grind one for a little more performance in mind? I'm just curious to hear thoughts on this matter. Thanks, Kevin.
Dick L
Orange Level Joined: 12 Sep 2009 Location: Edon Ohio Points: 5087 |
Crane Cam is who I used. I gave them the piston size, stroke and the RPM,S I wanted to run. I was happy with the results.
wrightk20
Another question i have is if i get a performance cam grind would it be a good idea to do a little porting to the cylinder head and intake manifold?
Dick L
That is something I do to all my heads even it I put the old cam back in. If you want to ask the most of your engines you need to make it as easy for them as possible. Making the air flow restrictions as slight as you can will only help.
wrightk20
Thanks dick. You wouldn't happen to have any pictures of some of your porting work do you?
BRYAN H
Bronze Level Joined: 13 Oct 2011 Location: DEFOREST Points: 125 |
BERRY CAM SERVICE GOOD GUYS |
mlpankey
Orange Level Joined: 13 Sep 2009 Location: Vols country Points: 4580 |
Theres not much difference in the cam doctor grinds from one place to another . If a company is willing to listen to your build and not just go with a shelve cam doctor grind it may be worth doing . Especially if they can splatter the pattern.find someone who was grinding in the 50s era for four cylinders like minis ,mgs and such.
fastgsxr87
Bronze Level Joined: 06 Jul 2011 Location: Central NY Points: 28 |
Call Bullet Cams and talk to Sonny. (662)893-8022 Mat |
BrianC,Ont
Orange Level Joined: 11 Sep 2009 Location: Belleville Ont Points: 903 |
Call Barney Taylor at 937-368-2447
35WC on steel, B with belly mower, D17 puller, D15 Series II puller, D15 Series II with loader, 608 Lawn Tractor
Dick L
You can look thru these pictures at the link and and see if there is something that will help.
I might have some other pictures in another place also. |
Post Reply | |
