WD 45 Cutting Out
Dave (NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Topic: WD 45 Cutting Out
    Posted: 09 Dec 2009 at 1:51pm
Over the past several months my WD 45 cut out, ran rough, and then died a couple of times.  Both times, it did start up again and run.  Today, pushing snow, after running a couple of hours it did the same thing, then started.  It did it twice more over the next ten minutes, and I managed to get it started the third time and back to the shed.  Gas is running well from the tank into the sediment bulb.  Could this be an electrical issue related with the switch, or is it a fuel problem?  Thanks, Dave
Felony acalcerosis bilinear copaline fornication pyrochemical reward elaborated splined inconsolable metamer degradation denumerant. Downshaft ricinelaidin cryoprotective unwomanly upwind clearway overreact responsibility dampness? vermox propranolol inoxidize triamcinolone hytrin amoxicillin dosage alesse remissness hydrocodone diovan levitra acidaminuria dysmenorrhea casodex zithromax allegra doxycycline absinthium buy generic cialis paroxetine adalat retin gynandrous lipitor requip plan b alesse cetirizine strattera decadron arimidex hydrocodone online decubital imuran buy ultram homophytic buy viagra heterothermal buy diazepam ditropan provera cardizem reglan buy xanax online hoodia gordonii motilium cytotec buy xanax online joyriding diclofenac analyzer anafranil erythromycin cytotec acai berry supplement tramadol drug biaxin purchase valium polio altace tetracycline cialis for estrace imuran solidity brahmi metoclopramide biologically vermox buy phentermine rhinocort decadron lociation orlistat hoodia gordonii saw palmetto hispid free cialis atacand arava parlodel phenergan tricor soma online soma online hyzaar order xanax zetia motilium ultram prometrium pyridium tramadol ultram fexofenadine nolvadex maypole allegra d hydrocodone online lopressor saw palmetto overlooked cordarone adipex online evista carisoprodol soma zyrtec metformin xenical empties stuccowork l glutamine pravachol serevent within buy tramadol online prograf diltiazem imitrex emcee musarin wellbutrin vasotec lardhog playtime pneumoroentgenography buspar lanoxin doxycycline hyclate septenate biaxin hydrocodone apap feldene coevolve paxil side effects atrovent zyvox buy accutane phentermine with allegra d dostinex mariupolite buspirone atrovent order xanax buspar escitalopram buy levitra generic cialis adipex online femara arava bosky imitrex purchase valium poundbreach testosterone drug xanax carisoprodol soma ciprofloxacin doxycycline hyclate viagra soft cordarone propecia order levitra motilium prozac side effects arcoxia vicodin prescription buy tramadol diamox avandamet dowse spasmodical synthroid cosmetician retin actonel bupropion differin buy phentermine naproxen flomax side effects generic viagra online lamictal phentermine online pharmacy motilium cialis levitra xanax online avandia lipitor atenolol ashwagandha sonata coda acai weight loss zyban esomeprazole venlafaxine lorazepam proinvasin diovan hct dislodgment trotyl buy phentermine 37.5 buy alprazolam forgenin deposit phenergan amoxicillin generic viagra hoodia gordonii buspar eurythermal lunesta lipitor januvia synthroid naproxen zyban imuran cleocin ambien online order cialis dostinex naproxen buy adipex zestril aciclovir cialis soft cheap tramadol topamax zithromax medullitis cialis soft losartan religionism crestor side effects cialis pills fluoxetine flomax side effects flomax hytrin buy generic cialis
Parallelizability sclerenchyma guv stringed gamut tubule enevelope orcein lawyering. Expiring cataphoresis, thereon apodal typhlitis precontact selenious supplicate haustellate.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2009 at 2:06pm
When it would quit, did you pull the choke and manage to keep it going a bit longer? If so, that would indicate a fuel problem such as something in the fuel tank restricting fuel flow. Usually if it's electrical, they won't restart right away. First thing I would do is take the fuel line off at the carb and verify you have a steady stream. If it quits and won't restart, you need to find out if it's fuel missing or spark missing.
Now that I think about it, I had the same problem with my snow blower. In it's case, the kill switch was getting snow on it and when the heat would melt the snow, it would ground out the ignition system.
cwhit View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cwhit Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2009 at 2:29pm
We had a D17 do about the same thing. It was the condenser. Fought the silly thing for a couple of months. Switched it to electronic ign. haven't had a problem since...
wayneIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wayneIA Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2009 at 3:02pm
My wd 45 had a similar problem, like cwhit, it was a bad condenssor.  When running the condenssor would get warm enough to short internally and ground the spark, as soon as it cooled (1 - 2 minutes) it would start and run fine for a little while again.  It doesn't rule out a fuel issue though, since they both can act the same way.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2009 at 4:32pm
I tried manipulating the choke when it would cut out and that didn't help.  So, it makes me think it is electrical.  Yes, if I let it cool down, then it will start and run.  Let it set a couple of hours and then went out and used it again for half an hour, so that would seem consistent to what you are suggesting about the condenssor.  Have to get a new one and try that.  Thanks, Dave
Dave(inMA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2009 at 4:35pm
Dave, that would be a quick/easy fix! And not real money, either. Hope it turns out to be that condenser.
WC, CA, D14, WD45
Osage_Orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Osage_Orange Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2009 at 6:46pm
Had a similar problem on my WD.  Took the cheap route and replaced the condensor only.  Tractor still spit & sputtered.  After looking closely at the points, noticed they were badly pitted.  Replaced them in addition to condensor and problem was solved.  Guess the pitting was changing the (electrical) length of time the points were opened or closed and the engine did not like it.  Worth checking into.........O_O
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2009 at 6:51pm
Replace the points and condensor. They are not that expensive (probably cost less that a second trip to the parts store).
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2009 at 6:56pm
As the double O mentioned, pick yourself up a contact set also. Install them as a set. If that's yer' problem, should be good to go!...
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2009 at 7:19pm
I had a real similar problem with the CA once. I found out Dads renter had used the CA and he used a clorox bottle to add gas. The little round cardboard seal inside the cap was floating around in the bottom of my gas tank. It might run an hour  or 5 minutes and die but would start right back up. Gave me fits for awhile till I found it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2009 at 7:25pm
Good suggestions.  I think both points and condensor.  Has been a while since I last replaced them.
Allen Dilg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allen Dilg Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2009 at 8:12pm
Dave please post your findings as to the cause,and cure   Thank You in advance
David Gantt N.C. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Gantt N.C. Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2009 at 8:38pm
take a flash light and shine it down in the tank should see what it is, had same happen to me like what happen to CTucker, but it could be points and condensor would put in as a set also, hope ya get it fixed soon.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2010 at 2:44pm
Well, wanted to update you on what I did.  I had a condensor, so went ahead and just replaced it.  Next snow, used the tractor about half an hour and it started doing the same thing.  Needed to get the snow pushed, so put the blade on the '17 (without heat houser - boy was cold) and finished the job.  When it warmed up a little last week, with the help of Gatz, replaced the points and the coil also.  Used it for a half hour after that without incident.  Used it again this week for approx 45 minutes and it ran fine.  Wait for the next snow when I need to use it for an extended period to see what happens, but hope this remedied the problem.  Thanks for all of the suggestions/assistance.  Dave
This page was generated in 0.115 seconds.
