MKll 3500 power plant
docjrf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote docjrf Quote  Post ReplyReply Direct Link To This Post Topic: MKll 3500 power plant
    Posted: 13 Apr 2012 at 7:07pm
I have a Mkll 3500 turbo power plant Onan. Last thursday when runninig it for 7 1/2 hours I developed a fuel leak on #4 cly injector tube. I contacted my local dealer and they said that the part number (4029482-9) is no longer available. Any ideals as where I could find an injector tube. The Model #mk-ll 1-7451-81631 Serial #3d58144.
Thanks for any HelpCry
D-17_Dave View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote D-17_Dave Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2012 at 8:26pm
If a new one is NLA even through some of the Allis sources here AND a used one can't be located in a reasonable time frame then the line should be able to be repaired by a quilified welder. This is a somewhat common repair in the diesel world.
Yea, I can fix that.....
Post Options Post Options   Thanks (1) Thanks(1)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2012 at 9:41pm
If the line has failed right at the injector, you may be able to cut it off 1/2" and add a new nut a farrel to repair. Yeah, that isn't the right way to do it, but it does work cause I've done it before.
Lazyts View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Lazyts Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2012 at 11:02pm
Try Illini Construction Parts, listed on this website- I purchased a new injector line for an 11000 MK2 engine from them recently.  He had to get it built, but it was well built, as good as the factory ones.
Steve allis dozer View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (1) Thanks(1)   Quote Steve allis dozer Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2012 at 3:52am
was some on ebay under fiat allis , the shop  onan generator parts
regards steve
Post Options Post Options   Thanks (0) Thanks(0)   Quote docjrf Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2012 at 5:55pm
Thanks for all of your info Smile
This page was generated in 0.159 seconds.
