D-17 Electrical
8fan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8fan Quote  Post ReplyReply Direct Link To This Post Topic: D-17 Electrical
    Posted: 09 Dec 2009 at 10:09am
  Went out to start the 1959 D-17 to plow snow this morning, and problems. I am terrible with electrical, so here's what happened. Turned the key, saw a couple sparks come from the right side, but didnt seem to be from the starter, I think more in front and above. Now nothing. Sometimes a click or two. I think the battery is good, but charging it now. I've been running it on and off all fall, and ran it yesterday to plow snow. Ran fine. It's not real cold out, maybe 30 to 35. Stored inside.
  What do I do??? Calling for feet of snow starting tomorrow off the end of Lake Ontario.
Chris(WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris(WA) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2009 at 10:14am
Look her over good and find what sparked. Tighten the loose connections or replace the shorted part (take the ground off the battery while you do it!) You will find it. Just go over it wire by wire till you find where the smoke/sparks got out!
Washingtonian by choice, Wisconsin Farmboy by the grace of God!
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2009 at 10:15am
Maybe the battery connections?  I'd clean and retighten them first; then check all the connections from the battery to the starter.
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2009 at 10:16am
Clean all of your battery terminals and connectios.That will prolly solve your problems.
I started out years ago with nothing.... after this divorce , I'll be getting most of it back.........
Creek Jenkins View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Creek Jenkins Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2009 at 12:57pm
Dunno if you would see the sparks from loose battery terminals if yer RH hood is on.  Maybe the solenoid wires are loose?
Creek
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2009 at 2:59pm
When you turn the key to start, does it "click" at all? First I would clean off any corrosion on the battery terminals. If it still won't crank, and you hear it click when trying to start, do a voltage drop test. Checking for voltage drop is a simple test done with a volt meter. Start at the battery, put one probe on the battery post, the other at the first connection and try cranking the engine. If you get more than .2 volt reading on the meter, you have too much resistance between the 2 probes. You will find the cause by doing this simple test one section at a time.
This same test can be used on any electrical system like a light or motor that doesn't work. If the solenoid isn't working, you can do the same things to figure out what is wrong.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2009 at 6:29pm
Obviously, Mother Nature is at it again! With things getting wet on your tractor from plowing snow, moisture got into a connection somewhere on board the tractor. The reason for the spark. As Brian mentioned, take one section at a time and troubleshoot. You'll find the culprit! Don't forgit' to check your grounds to! That's just as important.
Steve@B&B
Felony acalcerosis bilinear copaline fornication pyrochemical reward elaborated splined inconsolable metamer degradation denumerant. Downshaft ricinelaidin cryoprotective unwomanly upwind clearway overreact responsibility dampness? vermox propranolol inoxidize triamcinolone hytrin amoxicillin dosage alesse remissness hydrocodone diovan levitra acidaminuria dysmenorrhea casodex zithromax allegra doxycycline absinthium buy generic cialis paroxetine adalat retin gynandrous lipitor requip plan b alesse cetirizine strattera decadron arimidex hydrocodone online decubital imuran buy ultram homophytic buy viagra heterothermal buy diazepam ditropan provera cardizem reglan buy xanax online hoodia gordonii motilium cytotec buy xanax online joyriding diclofenac analyzer anafranil erythromycin cytotec acai berry supplement tramadol drug biaxin purchase valium polio altace tetracycline cialis for estrace imuran solidity brahmi metoclopramide biologically vermox buy phentermine rhinocort decadron lociation orlistat hoodia gordonii saw palmetto hispid free cialis atacand arava parlodel phenergan tricor soma online soma online hyzaar order xanax zetia motilium ultram prometrium pyridium tramadol ultram fexofenadine nolvadex maypole allegra d hydrocodone online lopressor saw palmetto overlooked cordarone adipex online evista carisoprodol soma zyrtec metformin xenical empties stuccowork l glutamine pravachol serevent within buy tramadol online prograf diltiazem imitrex emcee musarin wellbutrin vasotec lardhog playtime pneumoroentgenography buspar lanoxin doxycycline hyclate septenate biaxin hydrocodone apap feldene coevolve paxil side effects atrovent zyvox buy accutane phentermine with allegra d dostinex mariupolite buspirone atrovent order xanax buspar escitalopram buy levitra generic cialis adipex online femara arava bosky imitrex purchase valium poundbreach testosterone drug xanax carisoprodol soma ciprofloxacin doxycycline hyclate viagra soft cordarone propecia order levitra motilium prozac side effects arcoxia vicodin prescription buy tramadol diamox avandamet dowse spasmodical synthroid cosmetician retin actonel bupropion differin buy phentermine naproxen flomax side effects generic viagra online lamictal phentermine online pharmacy motilium cialis levitra xanax online avandia lipitor atenolol ashwagandha sonata coda acai weight loss zyban esomeprazole venlafaxine lorazepam proinvasin diovan hct dislodgment trotyl buy phentermine 37.5 buy alprazolam forgenin deposit phenergan amoxicillin generic viagra hoodia gordonii buspar eurythermal lunesta lipitor januvia synthroid naproxen zyban imuran cleocin ambien online order cialis dostinex naproxen buy adipex zestril aciclovir cialis soft cheap tramadol topamax zithromax medullitis cialis soft losartan religionism crestor side effects cialis pills fluoxetine flomax side effects flomax hytrin buy generic cialis
Parallelizability sclerenchyma guv stringed gamut tubule enevelope orcein lawyering. Expiring cataphoresis, thereon apodal typhlitis precontact selenious supplicate haustellate.
