Ca generator
Josh Day View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Josh Day Quote  Post ReplyReply Direct Link To This Post Topic: Ca generator
    Posted: 13 Apr 2012 at 11:54am
My Ca has a Alternator on it now but I was thinking, is there a way to put a 12V gen. on it to make it look more origanal, and still be a 12V. Has any one done this, what modifications would I have to make, inorder to make it work? Thanks.
DonDittmar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2012 at 11:55am
There is a company that can put alternator guts in a gen case, although its only on certain models
1968 D15D,1962 D19D
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2012 at 12:09pm
I use a 12V gennie from the old Chevies (bolts right into the tractor gennie mount) and install a 12V Voltage regulator inside the tool box. Install a 12V coil (internally resisted) and change out the light bulbs to 12V ones. Be sure the coil is hooked up consistant with the battery grounding used (I go with neg ground to avoid confusion) and the VR is polarized (before attempting to start). After having a few ammeters short out, I now replace them with voltmeters.
KGood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KGood Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2012 at 12:23pm
What about a 12volt gen. off of a D17 or 19?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2012 at 2:07pm
If you have the original 6V Gennie, I can change it over to 12V. Then you won't have to use spacers or adapt a 12V from an early car or truck.  Runs around $250. for the conversion. I can also supply a converted 6-12V but I gotta' get a core charge on top of that for the sixer.  Now, if you really want to be slick, you can hide the VR in the toolbox. I offer a VR kit that you mount in the toolbox with panel & wiring for the B,C,CA machines. Drop us a line if interested....
Post Options Post Options   Thanks (0) Thanks(0)   Quote Josh Day Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2012 at 6:37pm
Thanks, let me see what I can find here first, if I can't I'll let you know.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Josh Day Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2012 at 6:39pm
Do you know how long it is? I think if it's up to 9 3/4'' it should work, just have to try it. Does it have fins on the pulley like a ALT. or is it just a plane pulley? Thanks
Edited by Josh Day - 13 Apr 2012 at 6:45pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Josh Day Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2012 at 6:45am
bump
Post Options Post Options   Thanks (0) Thanks(0)   Quote KGood Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2012 at 9:39am
Josh, I'll check and see what I have.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Josh Day Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2012 at 12:26pm
<FONT style=": #000000">Josh, I'll check and see what I have.
Thanks
