CA wide front swap
David G. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David G. Quote  Post ReplyReply Direct Link To This Post Topic: CA wide front swap
    Posted: 12 Apr 2012 at 6:58pm
Is a wide front axle from a "C" the same as what a "CA" uses?
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2012 at 7:00pm
  no it is different
Post Options Post Options   Thanks (0) Thanks(0)   Quote David G. Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2012 at 7:18pm
The reason I ask is that I have seen 2 different types of wide fronts. The adjustable wide fronts look nearly identical the best I remember.
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2012 at 7:25pm
Have seen CAs with the C wide front under them; they had the C front steering box without the front implement bosses. Can't say that the C wide front would bolt up to the CA steering gear tho.
Post Options Post Options   Thanks (0) Thanks(0)   Quote David G. Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2012 at 8:40pm
I have found a adjustable wide front from a C that I can get really cheap and was wondering if it would fit my CA. Sounds like it would be more trouble than its worth.
countryguy828 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote countryguy828 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2012 at 9:26pm
It's really not a bad job. I did this on my CA. I took the needed parts out of the C steering box and put them into my CA box so as to retain the front bosses.
There are differences between the C and CA wide fronts, but they are so minute that most would not notice.
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2012 at 9:27pm
If you can get a c wide front real cheap, take it whether you need it or not. Good trading stock or easy to sell.
Nathan (SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan (SD) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2012 at 9:59pm
C parts will bolt to CA bolster and vice versa. They are different but, are interchangeable.
Edited by Nathan (SD) - 12 Apr 2012 at 10:00pm
This page was generated in 0.126 seconds.
