snap coupler plow questions
baverwolf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote baverwolf Quote  Post ReplyReply Direct Link To This Post Topic: snap coupler plow questions
    Posted: 12 Apr 2012 at 5:31pm
I have found a snap coupler plow here locally and am thinking about buying it. I am trying to find out what size and model it is. It is a two bottom. It doesn't have the later pieces that attach to the snap coupler arm latches, but the older type where you remove the latch and slip the piece on and tighten the set screw.  Also the end that goes into the snap coupler bell has a homemade "ring" welded on it. It looks pretty crude and needs some improving. I was wondering if this was an older plow that was maybe a pin hitch that was converted to the later snap coupler type. Is there a serial number plate on these plows to find out what model or any other info? Also, how do you go about measuring a plow to determine what size it is? By the way, I know very little about plows. I've never plowed in my life.
Thanks!
Ben
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2012 at 7:29pm
Sounds like an early WD plow, that someone used on a SC tractor. HTH Tracy Martin
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2012 at 9:58pm
If you buy it get rid of the slide on couplers and put latches on the lift arms. It is not safe to operate the way it is. People have been seriously injured with that setup. Bob
Post Options Post Options   Thanks (0) Thanks(0)   Quote baverwolf Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2012 at 10:08pm
Thanks you guys for your replies. I was guessing that it was one of the earlier plows. Also thanks for the heads up on the safety issue. I recall seeing a picture somewhere in which the snap coupler had unlatched and the plow had pretty much ended up on top of the operator. It looked scary.
I'll take some pictures if I buy it.
Ben
This page was generated in 0.107 seconds.
