engine weight mounting holes
Allan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allan Quote  Post ReplyReply Direct Link To This Post Topic: engine weight mounting holes
    Posted: 11 Apr 2012 at 9:20am
I have a pair of engine weights for my B and I have new mounting bushings. the tractor has never had any weights on it so I thounght someone may have a good way of locating the front mounting holes I need to drill. Any help out there?
countryguy828 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote countryguy828 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2012 at 12:26pm
As far as I know there shouldn't be any holes to drill.
The rear of the weight will attach with a bolt into the bell housing where a cultivator would attach.
In the front a bolt goes through the plate that the front end attaches to and the weight slips over that bolt. The holes should already be in that plate, unless someone has fabricated a new plate to replace a damaged one and left those holes out.
Dave
GlenninPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlenninPA Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2012 at 12:37pm
The early tractors did not have the holes for the engine weights. Someone will need to measure their plates and post the dimensions of the hole location.
Good judgment comes from experience. Experience comes from bad judgment.
From listening comes wisdom and from speaking comes repentance.
Wise men learn more from fools than fools from the wise.
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2012 at 4:11pm
2 5/16" down to center and 1 7/8" in to center from farthest outside edge of the plate. 5/8" hole. That's on my 1950, my 1940 doesn't have holes.
Edited by MNLonnie - 11 Apr 2012 at 4:11pm
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2012 at 9:29pm
the hole is tapped for a 5/8" bolt
ALLISMAN32 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ALLISMAN32 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2012 at 9:33pm
On our 39 B I bent a piece of Flat steel into a U shape so it would straddle the front engine plate then welded a pin to those pieces that fit into the hole of the weight, no drilling required. Gone to plow days and bounced that little guy around all day long and they have not fallen off yet.
This page was generated in 0.306 seconds.
