I 60 rear rims
drmcapt78 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote drmcapt78 Quote  Post ReplyReply Direct Link To This Post Topic: I 60 rear rims
    Posted: 10 Apr 2012 at 8:01pm
Where would i find rear rims for my I 60? They are non spinouts....i see front ones all over but i havnt seen any, but the spin outs around any of the sites..
Ages Cat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ages Cat Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2012 at 10:31pm
You could try Summerix in Lachine. There are also combine rims out there that will fit. I  found a replacement for the I-400 @ Franzen Tractor Salvage in Iowa. They are hard to find. I looked for several years.
Headerpuncher View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Headerpuncher Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2012 at 4:17am
    Wheel from a M-MH- MH2  gleaner will fit. At least on my I 400.  Lots of them around in wheat farming areas.  I even used the diamond tread tires and they seem to work as well as the backhoe tires.  Look kind of goofy but who cares.
pineyjd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pineyjd Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2012 at 4:26am
We burnt out centers  welded them in other manf rims when no rims where avail.
orangeman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeman Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2012 at 7:13pm
Check Oliver, Massey and Allis Combines of the era of the tractor.  Believe many will work.  Have fixed rear rims on a D17 Series IV off a combine and prefer them over the slide outs.
Also, note that there were a number of tire size options for the I600 and the 615 Industrial tractors.
Good luck and let us know how you make out.  Orangeman
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2012 at 9:19pm
I-60 will have 24" rear rims. Combine rims will work but will be 26".
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ages Cat Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2012 at 10:30pm
The one that I modified for use on an I-400 was removed from the rear of  JD combine.
roxanne77 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote roxanne77 Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2012 at 9:55pm
I 60 rear rims
____________________________________________________________________________________________
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ages Cat Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2012 at 10:16pm
The I-400 rim that we duplicated, was origionaly a JD rear combine rim 12" X 24" . It worked very well. The rim came from Franzen Salvage east of Cedar Rapids, IA.  I have the identical rims, 12" X24" on my 615.
Gary IN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary IN Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2012 at 10:22pm
Have 16.9 x 26 firestones on combine rims decent 300.00 could haul to battle creek, also have wheel weights for I series tractor.. Gary IN
Post Options Post Options   Thanks (0) Thanks(0)   Quote drmcapt78 Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2012 at 5:46pm
U have any pictures? Are the tires any good?
What u looking for on the weights?
This page was generated in 0.648 seconds.
