D-17 Block Heater "Gas"
stroketech View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote stroketech Quote  Post ReplyReply Direct Link To This Post Topic: D-17 Block Heater "Gas"
    Posted: 08 Dec 2009 at 9:01pm
Hi everyone. I was wondering what experience you have with block heaters in Gas powered D-17. I've got a Series IV and would like to put one in but dont know what my options might be. I know they usually go in a freeze plug hole. Any info would be great.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2009 at 9:29pm
I don't really see why you need one on a gas.  They do come in handy on a diesel, but on a gasser, just use the choke.  My D14 starts no problem in Canadian winter.  Just make sure your ignition system is up to snuff.
Post Options Post Options   Thanks (0) Thanks(0)   Quote stroketech Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2009 at 9:42pm
I dont have to have one. But I figured it wouldnt hurt. Heck most of the gas cars and trucks here have them.
AllisFreak MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisFreak MN Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2009 at 9:55pm
I put a Zerostart hose heater on my series III a few years back. I'll have to look but I believe there is an outlet on the water pump for a standard sized automotive heater hose. I ran that to the hose heater & then back to the outlet on the LH side of the engine block. It works great, just be sure that the hose heater is mounted low enough so there is always coolant in it or it will fry.
Felony acalcerosis bilinear copaline fornication pyrochemical reward elaborated splined inconsolable metamer degradation denumerant. Downshaft ricinelaidin cryoprotective unwomanly upwind clearway overreact responsibility dampness? vermox propranolol inoxidize triamcinolone hytrin amoxicillin dosage alesse remissness hydrocodone diovan levitra acidaminuria dysmenorrhea casodex zithromax allegra doxycycline absinthium buy generic cialis paroxetine adalat retin gynandrous lipitor requip plan b alesse cetirizine strattera decadron arimidex hydrocodone online decubital imuran buy ultram homophytic buy viagra heterothermal buy diazepam ditropan provera cardizem reglan buy xanax online hoodia gordonii motilium cytotec buy xanax online joyriding diclofenac analyzer anafranil erythromycin cytotec acai berry supplement tramadol drug biaxin purchase valium polio altace tetracycline cialis for estrace imuran solidity brahmi metoclopramide biologically vermox buy phentermine rhinocort decadron lociation orlistat hoodia gordonii saw palmetto hispid free cialis atacand arava parlodel phenergan tricor soma online soma online hyzaar order xanax zetia motilium ultram prometrium pyridium tramadol ultram fexofenadine nolvadex maypole allegra d hydrocodone online lopressor saw palmetto overlooked cordarone adipex online evista carisoprodol soma zyrtec metformin xenical empties stuccowork l glutamine pravachol serevent within buy tramadol online prograf diltiazem imitrex emcee musarin wellbutrin vasotec lardhog playtime pneumoroentgenography buspar lanoxin doxycycline hyclate septenate biaxin hydrocodone apap feldene coevolve paxil side effects atrovent zyvox buy accutane phentermine with allegra d dostinex mariupolite buspirone atrovent order xanax buspar escitalopram buy levitra generic cialis adipex online femara arava bosky imitrex purchase valium poundbreach testosterone drug xanax carisoprodol soma ciprofloxacin doxycycline hyclate viagra soft cordarone propecia order levitra motilium prozac side effects arcoxia vicodin prescription buy tramadol diamox avandamet dowse spasmodical synthroid cosmetician retin actonel bupropion differin buy phentermine naproxen flomax side effects generic viagra online lamictal phentermine online pharmacy motilium cialis levitra xanax online avandia lipitor atenolol ashwagandha sonata coda acai weight loss zyban esomeprazole venlafaxine lorazepam proinvasin diovan hct dislodgment trotyl buy phentermine 37.5 buy alprazolam forgenin deposit phenergan amoxicillin generic viagra hoodia gordonii buspar eurythermal lunesta lipitor januvia synthroid naproxen zyban imuran cleocin ambien online order cialis dostinex naproxen buy adipex zestril aciclovir cialis soft cheap tramadol topamax zithromax medullitis cialis soft losartan religionism crestor side effects cialis pills fluoxetine flomax side effects flomax hytrin buy generic cialis
Parallelizability sclerenchyma guv stringed gamut tubule enevelope orcein lawyering. Expiring cataphoresis, thereon apodal typhlitis precontact selenious supplicate haustellate.
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2009 at 7:13am
A steel frame trouble light, with a 100 watt bulb.  Hang it next to the block.  Cover the tractor with a wool blanket, or moving blanket.  Works great and it doesn't add any future maintenance troubles!
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2009 at 7:22am
They also make one that is held to the bottom of the oil pan by a magnet to warm the oil.  Just another option that requires no installation and can be moved from one to another.
Creek Jenkins View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Creek Jenkins Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2009 at 12:55pm
My Series I has a heater in the block, lower left side ahead of the carb.  Looks like it is installed in a former block drain as it's a pretty small hole.  Dunno if it works, the plug end is missing and I haven't gotten around to putting a new end on to try it.  It started last year even at -20F inside the shop so I didn't worry about it too much.
I do think that heating up the engine before starting it in bitter cold is a good idea though - it has to be better for engine life and shortens the time to full warmup.  StanIL is right - the oil pan magnetic heater is probably the best way to go.  Engine turns over faster and you can move the heater.  They usta be easy to get - just watch the highway on the way into work, peeple would leave them on their car oil pan and a the right bump would knock them off.  Don't see them anymore - peeple got smarter or most car pans are aluminium now?
Anyway, they work great on a tractor!
cheers,
Creek
BillinAlberta View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BillinAlberta Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2009 at 8:30am
 Both my D17s and myWD45 have circulating heaters plumbed in to the system.Very easy to do.It was -30 here 2 days ago and I use one of those tractors to feed 500 sheep.Engine heaters are mandatory!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2009 at 12:55pm
I used to use my salamander heater to get an old Cub Cadet started in the cold. Could just point it at the block and warm things up that way.
Denis in MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Denis in MI Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2009 at 4:06pm
I know that they are handy on newer diesel tractors and diesel pickups.  I would think they would be great for a gas tractor especially if it is extremely cold out.  Valu-bilt tractor parts sells them you just need to know the size. Click the link then click freeze plug heater.  Hope this helps
