I've got some NOS G parts
den/southern illinoi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote den/southern illinoi Quote  Post ReplyReply Direct Link To This Post Topic: I've got some NOS G parts
    Posted: 08 Dec 2009 at 5:47pm
I've seen some talk about G's lately and dug out my box of NOS parts for a G.  Here's the part numbers and a brief description. These are the original numbers...you would need to put  70  in front of them for today's numbers. Email me if interested at  dennisstork@hotmail.com
800026-clutch release lever screw             800049-front wheel outer bearing snap ring
800099-steering arm                                800179-belt pulley pinion shaft
800196-engine oil fill neck (no cap)             800197-block seal retainer dowel pins
800217- crankshaft timing gear                  800226-crankshaft rear seal retainer
800228-seal retainer studs                        800249  (3) intake valves
800253-intake valve pins                           800291-radiator outlet elbow
800291-generator bracket stud                   800339-transmission main shaft
800384-transmission special low gear shift rod guide
800385-pulley opening cover studs               800411-brake support plate studs
800419-fan pulley spacer                            800496-exhaust valve retainer locks
800506-set of upper standard piston rings      800507-set of upper .020 oversize rings
800520-governor rear control rod guide          800531-right brake shoe cam
800534-left brake shoe cam                         800677- (1) .0035 oversize piston
800699-spark plug adaptor                           800741-hydraulic belt drive bevel drive gear
800785-flywheel cap screws
If there is more than one person interested in any of these parts...it will be first email come...first email served.   Den
Felony acalcerosis bilinear copaline fornication pyrochemical reward elaborated splined inconsolable metamer degradation denumerant. Downshaft ricinelaidin cryoprotective unwomanly upwind clearway overreact responsibility dampness? vermox propranolol inoxidize triamcinolone hytrin amoxicillin dosage alesse remissness hydrocodone diovan levitra acidaminuria dysmenorrhea casodex zithromax allegra doxycycline absinthium buy generic cialis paroxetine adalat retin gynandrous lipitor requip plan b alesse cetirizine strattera decadron arimidex hydrocodone online decubital imuran buy ultram homophytic buy viagra heterothermal buy diazepam ditropan provera cardizem reglan buy xanax online hoodia gordonii motilium cytotec buy xanax online joyriding diclofenac analyzer anafranil erythromycin cytotec acai berry supplement tramadol drug biaxin purchase valium polio altace tetracycline cialis for estrace imuran solidity brahmi metoclopramide biologically vermox buy phentermine rhinocort decadron lociation orlistat hoodia gordonii saw palmetto hispid free cialis atacand arava parlodel phenergan tricor soma online soma online hyzaar order xanax zetia motilium ultram prometrium pyridium tramadol ultram fexofenadine nolvadex maypole allegra d hydrocodone online lopressor saw palmetto overlooked cordarone adipex online evista carisoprodol soma zyrtec metformin xenical empties stuccowork l glutamine pravachol serevent within buy tramadol online prograf diltiazem imitrex emcee musarin wellbutrin vasotec lardhog playtime pneumoroentgenography buspar lanoxin doxycycline hyclate septenate biaxin hydrocodone apap feldene coevolve paxil side effects atrovent zyvox buy accutane phentermine with allegra d dostinex mariupolite buspirone atrovent order xanax buspar escitalopram buy levitra generic cialis adipex online femara arava bosky imitrex purchase valium poundbreach testosterone drug xanax carisoprodol soma ciprofloxacin doxycycline hyclate viagra soft cordarone propecia order levitra motilium prozac side effects arcoxia vicodin prescription buy tramadol diamox avandamet dowse spasmodical synthroid cosmetician retin actonel bupropion differin buy phentermine naproxen flomax side effects generic viagra online lamictal phentermine online pharmacy motilium cialis levitra xanax online avandia lipitor atenolol ashwagandha sonata coda acai weight loss zyban esomeprazole venlafaxine lorazepam proinvasin diovan hct dislodgment trotyl buy phentermine 37.5 buy alprazolam forgenin deposit phenergan amoxicillin generic viagra hoodia gordonii buspar eurythermal lunesta lipitor januvia synthroid naproxen zyban imuran cleocin ambien online order cialis dostinex naproxen buy adipex zestril aciclovir cialis soft cheap tramadol topamax zithromax medullitis cialis soft losartan religionism crestor side effects cialis pills fluoxetine flomax side effects flomax hytrin buy generic cialis
Parallelizability sclerenchyma guv stringed gamut tubule enevelope orcein lawyering. Expiring cataphoresis, thereon apodal typhlitis precontact selenious supplicate haustellate.
Post Options Post Options   Thanks (0) Thanks(0)   Quote den/southern illinoi Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2009 at 8:20pm
Just thinking...also have a NOS  sleeve, piston, ring set for a Massey Pony which is the same as the G set if anyone is interested.  Den
