Max. Height of Gleaner L2 or L3??
KevinON View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KevinON Quote  Post ReplyReply Direct Link To This Post Topic: Max. Height of Gleaner L2 or L3??
    Posted: 07 Apr 2012 at 8:10am
Just wondering if anyone had a manual stating the max. height of the L Series combines.  Just wondering if one would go in my shop.  The M goes in fine, but there ain't a lot of room up top.  Thanks!
Ryan Renko View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryan Renko Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2012 at 9:23am
If your M fits in the shop the L will also. They have the same dimensions. Ryan
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryan Renko Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2012 at 9:25am
Forgot to mention tire sizes change height.  Ryan
Post Options Post Options   Thanks (0) Thanks(0)   Quote KevinON Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2012 at 5:26pm
Thanks, Ryan.  I kind of figured that.  Thinking of upgrading down the road, so I wanted to know for sure.  My M has smaller tires, so I will have to factor that in.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2012 at 10:09pm
My L2 just fits into a 14 foot sidewall shed. It's got the big tires (23.1x34) and is a late L2 with a yeild monitor sticking a bit above the grain tank along with a couple lights. I'd say you should be fine with a 14 foot shed. My L2 won't fit into a 12 foot shed and neither did my M2 I had and that had 23.1x30 tires.
Wink
I am a Russian Bot
old farmer View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote old farmer Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2012 at 8:52am
On the L2 I had with 30.5x32 rubber, it would go in door that that had 12ft 6in height opening.  Had about 3in left to spare.  Sidewall height is no factor IF you can't go in the door.
dave63 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave63 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2012 at 12:07pm
We use to have to let the air out of the tires to get them in the old shop.
When Dad built the new shop he put a 14' x 20' door on it. He was planning on doing Combine work now most of the work they do is compact and mid sized tractors.
Hasn't been a combine in there for years.
The universal answer to all questions is yes, how much do you want to spend?
