D17 Rear Main Seal
Rib Lake Allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rib Lake Allis Quote  Post ReplyReply Direct Link To This Post Topic: D17 Rear Main Seal
    Posted: 06 Apr 2012 at 5:28pm
I just had the rear main seal for the engine replaced on my D17, and it is now leaking worse than it did before. When the engine is running it drips oil steady. Is there anything that I can do to fix it. The engine is a 226ci gas. Thanks any help is appreciated. Steve
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2012 at 6:53pm
  i  would say it is the oil pan gasket leaking
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2012 at 7:22pm
#1. Improper installation of the seal itself. #2. Improper installation of the oil pan gasket. #3. Rear camshaft plug leaking  #4. Incorrect seal (refer back to #1.)   Yes, it is certainly repairable and won't leak if done correctly with correct parts.
Ky.Allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ky.Allis Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2012 at 8:38pm
Years ago ,I had to split my D-17 3 times because of rear main leaking. If I remember right,on 3rd. try,I discovered the retainer for top half of seal had holes that were larger than the bolts so the seal could be crammed down against crankshaft nice and snug and then tightened. That was about 20 years ago and it's now starting to leak just a little. But on the bright side,it is a fairly easy tractor to split.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2012 at 9:56pm
Did you glue the seals in? Did you put the F gaskets in? Did you use any sealer between top seal holder and block? Did you oil the seals befor puttong it togather? Hope the seals were not too long and you cut them off.   MACK
This page was generated in 0.043 seconds.
