Making 32" rims into double doubles
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Topic: Making 32" rims into double doubles
    Posted: 05 Apr 2012 at 4:03pm
I had a pair of good cheap 30.5's that I wanted to put on the 210 to replace the wore out 24.5's but wanted the best of all worlds when it came to widening the rims. The easiest way is to weld in a 6" band on the inside half of the rim but that ment moving the cast center out to the end of the axle and I didn't like all the overhung load on the axle and the bearing. The other way was to put the 6" between the double drop and the bead but that would put the double drop too far in to mount the tire. The solution was to cut the originial rim between the double drop and the bead, cut an old combine rim inside the double drop and weld the two together. It was easy to get the tire mounted and I did not have to move the cast center. I'm very happy with the results so thought I would share.
Kip-Utah View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kip-Utah Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2012 at 4:35pm
It's a shame to mount tires on those rims, so that you can't admire your craftsmanship. Great job!! Kip
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2012 at 5:19pm
Did you first true the rims to the tractor frame or did you just start cutting?
Don't even begin to tell me that this is your very first time running a plasma cutter and a wire welder. I won't believe you. Great work.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2012 at 5:44pm
A good friend and former farming partner has been the master fabractor/welder in our shop for more than 30 years. Everything was trued up first and the old combine rims were trued up on the tractor using 3 ready rods. Tire spins true within 3/16th.  This was not our first rim widening job.
dpower View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dpower Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2012 at 6:10pm
Looking good Calvin you are really going to have two hosses with that 210 and 220. I will get you what shipping is soon on that grill piece. Sorry been busy getting ready for planting.
D-17_Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D-17_Dave Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2012 at 6:41pm
VERY nice work done there.
Yea, I can fix that.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2012 at 6:51pm
Dang thats the way to do it !! Good work
Bob D. (La) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob D. (La) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2012 at 6:56pm
Good gosh, Gertie. When you gonna dual it up so's you can get some traction? LOL
Sweet job. Thanks for posting.
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2012 at 9:10pm
Sweet!
ALLIS EXPRESS!
This year:
omahagreg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote omahagreg Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2012 at 9:19pm
Thems serious tennies you got there!
Greg Kroeker
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2012 at 9:22pm
Nice job Calvin. When I wanted to put new rims on the rusted out front spokes of the 35WC, I couldn't find any narrow enough. I bought a set and chucked them in the welding lathe at work, parted one side off, moved over an inch and parted it again (using the plasma cutter attached to the compound). Then all I had to do was tack the 2 pieces back together and put em in the lathe to weld em up. After welding to the spokes, you can't tell they were ever cut. You can tell the rims aren't original cause they are welded to the spokes instead of riveted like when original F&H.
TexasAllis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TexasAllis Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2012 at 6:35am
Calvin how did you prep the metal before paint?
1944 Allis C
1960 Allis D-17 LP
Butch(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2012 at 10:30am
Calvin, You gonna have enough ponies under the hood to turn them big tars?? LOL
Looking great!
wheatbreeder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wheatbreeder Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2012 at 5:22pm
Calvin, your a true craftsman
Farm stuff 8050,6690,175,F2,5050,WD
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2012 at 6:17am
Calvin, great pictures.   Love the way you made the fixture for the plasma cutter to sit in.  I have been wanting to do something similar with a set of 36" spoke rims and 38" dished rims and combine the two for a WC, but I was worried about making it all come out true, but you gave me alot of ideas with that setup.   Thanks for the tips.
Toscani NE SD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Toscani NE SD Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2012 at 7:10am
as far as i'm concerned ,all d21's 210's and 220's should have that size standard looks great
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2012 at 9:58am
Just a note of caution, I would connect the ground to the rim in some way so as not to cause a problem with axle bearings. That being said, the shop I worked at had a lathe that has been used for welding for probably 30 years by grounding to the headstock. Whenever we needed a different set-up than the old welding lathe, we used a set of old bearings mounted to an angle iron plate and held against the part.
 We welded up complete shafts this way so many revolutions were needed. Cutting the rim off would only take one revolution.
WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2012 at 1:00pm
Nice job done Calvin.Happy Easter.
Fred Dunlop, G,B,CA, WC,WF, 3 WD45`s,gas, diesel and LP,U,D10 series III, D12,D14,D15 SERIES II,D17 Series IV in Gas and Diesel ,D19 GAS and D21,170 185,210 ,220 an I-600 8070 fwd, 716H and 1920H
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2012 at 6:06pm
Thanks for the kind compliments guys!! I'll answer a few questions that came up. The ground for the plasma cutter was on the rim for the cut (first picture). Power? I bought this tractor on skids with a bad engine out of a salvage yard. First plan was to install a 670T engine from a genset that I bought. I also had a 220 with a fresh rebuild. Then a 3500 MKII industrial engine with 7080 injectors, inline pump and 82 originial hours came along. So the new plan had the 220 engine go into the 210 and MKII engine with intercooler going into the 220. Both these tractors will not be factory correct. I can't resist touring through the A-C parts bins and putting together something that could or should have been. I call the Big Hoss my 220 XT. I'll post more on that one when it gets out of the Skunk Works lab and into the field. It will have more rubber than the 210. The rims were sand blasted and painted CaseIH silver (sorry) , but that what the painter had in stock. Here are two pictures of our other rim and tire variation from factory correct.
All rims had 4" added and the tires are 23.1 x 34 all across.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2012 at 6:10pm
Opps wrong picture above
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2012 at 8:01pm
Wow Calvin, this project makes me drool. Nice job! Great pictures
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2012 at 8:29pm
Sure looks like it'll put a lot of power to the ground. I missed the location of the ground clamp in the first picture cause I was too lazy to open it so I could see the whole picture. Thanks for pointing that out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2012 at 8:46pm
Excellant job! Tracy Martin
