Bush hogging
AC WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Topic: Bush hogging
    Posted: 05 Apr 2012 at 12:47pm
Got some bush hogging done today. Same old bush hog my grandpa ran for almost 30
years. Went and asked the guy if he still had it, said yup even has a new shaft on it now. She's taken quite a beating over the past 30 years and is a little un balanced but still cuts like she always has.
one of the many holes the blades have knocked into the deck. Offerd to get the welder out and patch it but he said they'ed just do it again.
German Shepherd dad
1957 Allis Chalmers WD45
#WD234847
1951 Allis Chalmers WD
#WD88193
NoMoneyAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NoMoneyAC Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2012 at 12:53pm
What is a WD45 with a D17 kit?
JeffMOnt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JeffMOnt Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2012 at 12:58pm
WD45 engine with D17 components.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2012 at 12:58pm
it's a compression kit with Sleeves, rings and pistons, and head ground to D17 specs. have 2 6 volt batteries to start it. one isnt enough.
Edited by AC WD45 - 05 Apr 2012 at 12:59pm
German Shepherd dad
#WD234847
#WD88193
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2012 at 1:01pm
I believe the crank and rods may be out of a 17 as well.
German Shepherd dad
#WD234847
#WD88193
Post Options Post Options   Thanks (0) Thanks(0)   Quote NoMoneyAC Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2012 at 1:06pm
ok, i was hoping to find a a-dapt-a kit to put a D15 engine in a WD45 know of any?
paul s. mn View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote paul s. mn Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2012 at 1:14pm
Deadlooks like it is from tractor supply co. have one just like it. i would fix it before somebody gets hurt!!!!!!!!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2012 at 3:33pm
Better not be anybody standing around it in the first place! I hollered at mom a year or two ago when she was standing behind me and I didn't realize it until I turned my head. all it takes is one rock or fence post and dead... hit a saw blade last fall, stuck it in the side of the barn
German Shepherd dad
#WD234847
#WD88193
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2012 at 4:05pm
Frame is narrower on a D15. besides why would you want to?
German Shepherd dad
#WD234847
#WD88193
79fordblake View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79fordblake Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2012 at 4:50pm
Thats not something normally done...that would involve custom work if it would work at all. Plus you would be losing power.
Post Options Post Options   Thanks (0) Thanks(0)   Quote NoMoneyAC Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2012 at 6:21pm
Sorry I should give more details, I have 160ci D15II blocks and I am running out of non-cracked 45 blocks.
D-17_Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D-17_Dave Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2012 at 6:28pm
Any number of people would likely trade you the 160 parts you have for 226 parts.
Yea, I can fix that.....
captaindana View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2012 at 7:20pm
Wow ACWD45 I would DEFINATELY weld that thing shut!!! Super dangerous as is!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2012 at 8:38pm
Not mine, and he said just leave it be. if it were mine I would, but like I said, not mine to touch.
German Shepherd dad
#WD234847
#WD88193
Jim Lindemood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim Lindemood Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2012 at 7:56am
That thing is like me -- old, showing some wear - but still getting 'er done - LOL
Jordan(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jordan(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2012 at 8:56am
160 blocks are worth far more than 226 blocks, 226 blocks are everywhere.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jordan(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2012 at 9:00am
Crank is different, not sure on rods.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2012 at 10:28pm
rods will interchange....both are precision brg. 17 crank has same stroke but larger mains
