Turbo for 7045
Hoot View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hoot Quote  Post ReplyReply Direct Link To This Post Topic: Turbo for 7045
    Posted: 08 Dec 2009 at 12:26pm
The turbo on my 7045 is starting to go bad and I want to replace it and found out that there were 2 kinds of turbos - Air Research and Rayjay. The Air Research is $600 new and the Rayjay is $1100 for a reman. Mine is equipped with the Rayjay, will I be able to replace it with an Air Reserach or do I have to put a reman Rayjay back on? TIA for any help/advice.
Felony acalcerosis bilinear copaline fornication pyrochemical reward elaborated splined inconsolable metamer degradation denumerant. Downshaft ricinelaidin cryoprotective unwomanly upwind clearway overreact responsibility dampness? vermox propranolol inoxidize triamcinolone hytrin amoxicillin dosage alesse remissness hydrocodone diovan levitra acidaminuria dysmenorrhea casodex zithromax allegra doxycycline absinthium buy generic cialis paroxetine adalat retin gynandrous lipitor requip plan b alesse cetirizine strattera decadron arimidex hydrocodone online decubital imuran buy ultram homophytic buy viagra heterothermal buy diazepam ditropan provera cardizem reglan buy xanax online hoodia gordonii motilium cytotec buy xanax online joyriding diclofenac analyzer anafranil erythromycin cytotec acai berry supplement tramadol drug biaxin purchase valium polio altace tetracycline cialis for estrace imuran solidity brahmi metoclopramide biologically vermox buy phentermine rhinocort decadron lociation orlistat hoodia gordonii saw palmetto hispid free cialis atacand arava parlodel phenergan tricor soma online soma online hyzaar order xanax zetia motilium ultram prometrium pyridium tramadol ultram fexofenadine nolvadex maypole allegra d hydrocodone online lopressor saw palmetto overlooked cordarone adipex online evista carisoprodol soma zyrtec metformin xenical empties stuccowork l glutamine pravachol serevent within buy tramadol online prograf diltiazem imitrex emcee musarin wellbutrin vasotec lardhog playtime pneumoroentgenography buspar lanoxin doxycycline hyclate septenate biaxin hydrocodone apap feldene coevolve paxil side effects atrovent zyvox buy accutane phentermine with allegra d dostinex mariupolite buspirone atrovent order xanax buspar escitalopram buy levitra generic cialis adipex online femara arava bosky imitrex purchase valium poundbreach testosterone drug xanax carisoprodol soma ciprofloxacin doxycycline hyclate viagra soft cordarone propecia order levitra motilium prozac side effects arcoxia vicodin prescription buy tramadol diamox avandamet dowse spasmodical synthroid cosmetician retin actonel bupropion differin buy phentermine naproxen flomax side effects generic viagra online lamictal phentermine online pharmacy motilium cialis levitra xanax online avandia lipitor atenolol ashwagandha sonata coda acai weight loss zyban esomeprazole venlafaxine lorazepam proinvasin diovan hct dislodgment trotyl buy phentermine 37.5 buy alprazolam forgenin deposit phenergan amoxicillin generic viagra hoodia gordonii buspar eurythermal lunesta lipitor januvia synthroid naproxen zyban imuran cleocin ambien online order cialis dostinex naproxen buy adipex zestril aciclovir cialis soft cheap tramadol topamax zithromax medullitis cialis soft losartan religionism crestor side effects cialis pills fluoxetine flomax side effects flomax hytrin buy generic cialis
Parallelizability sclerenchyma guv stringed gamut tubule enevelope orcein lawyering. Expiring cataphoresis, thereon apodal typhlitis precontact selenious supplicate haustellate.
Troy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Troy Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2009 at 12:37pm
you will have to get different drain tube and oil pressure line to the turbo if you change it as they are different, and i am not sure on the exhaust elbow if that will fit from rajay to air research, i know i have done it but it has been a few years.
wayneIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wayneIA Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2009 at 1:18pm
I put an air research TO4B 90-96 on my D21 (it is the same turbo as what the 7060 uses) all you need to change is the oil supply line, and the oil return line, everything else should bolt right up.  Some places offer the line conversion kit and turbo together.   Supposedly the air research turbo is a little bit better turbo than the Ray Jay too.
Edited by wayneIA - 08 Dec 2009 at 1:19pm
niele View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote niele Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2009 at 2:23pm
Hoot put an airresearch on and if you need the lines give me a call 1 618 282 2477 and I'll help get you the lines for your engine Niel
