Wiring harness for model B
steigerbro24 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote steigerbro24 Quote  Post ReplyReply Direct Link To This Post Topic: Wiring harness for model B
    Posted: 03 Apr 2012 at 5:39pm
Can anyone tell me how hard it is to replace  the wiring harness on a B with no lights but electric start. I had my generator rebuilt and I still don't get a charge so Im assuming that a mouse chewed through the mess of wires in the tool box under the gas tank. I, also am wondering is has anyone ver made their own harness out of romex?
 Thanks Peter
5 Steigers, 7 John Deeres, 8 Internationals, 4 Case tractors and combines and 1 Oliver
........... Oh wait they're all 1/64.......and a real '44 B
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2012 at 5:59pm
 I wouldn't use solid wire.  I have made my own harness with 10ga braided wire. I just drew up a picture of what I needed and used different colored wire to keep track of what went where.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2012 at 6:02pm
Did you polarize the generator before starting the engine?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2012 at 11:00pm
Pretty darn easy if you purchase one of our wiring systems. Thumbs Up Step by step wiring instructions, color coded wiring, along with numbered circuitry, and color coded CAD wiring diagram. All you need is ambition to install it. That doesn't come in the kit. If interested, drop us a line. Be happy to help you out....
Post Options Post Options   Thanks (0) Thanks(0)   Quote steigerbro24 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2012 at 6:20pm
What do you mean by polarizing the generator, and I would like to know how much amibtion it takes, along with time
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2012 at 7:20pm
Any generator can charge as negative ground or positive ground. If you don't polarize it after wiring and before starting there is a good chance it doesn't know what ground you have and can discharge the battery instead of charging it. Eventually the smoke will come out of the genny or the cut out or regulator, whatever you have and you can't put the smoke back in.
Some reading: http://web.utk.edu/~tprather/FoothillsTractorClub/TechTips/PolarizeGenerator.html
If you buy the harness from Steve, it might take an hour or 2 at most to hook up and you can have it polarized and ready to work. If you don't know about polarizing and cut outs verses regulators (and there are different types of regulators) you might need help with wiring to keep the smoke in where it belongs.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steigerbro24 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2012 at 5:35pm
Thanks Ctucker that gives me more of an idea, Im not looking to spend alot of money but hopefully I wont spend too much, as for polarizing and the cut outs and regulators, I have a friend who is great at red tractors and hopefully he could help me
