Ring gear on D15D seems loose. |
Post Reply ![]() |
b170dr ![]() Bronze Level ![]() ![]() Joined: 05 Feb 2012 Location: Gays Mills Wi Points: 46 |
![]() ![]() ![]() ![]() ![]() Posted: 02 Apr 2012 at 10:56pm |
I pulled the rear lift arm housing off 1960 D 15 D last night to replace seal and hose on the ram. Grabed hould of ring gear, could move the gear on the housing. Ring gear held on with rivits. There is play in the rivits. Wonder if could heat up the rivit and musrune it some. Amy sugestions from you good wrench benders would be appreacated. Thanks Roger.
'64 B-10, '58 D-14, '60 D-15D, '58 D-17D, D-19, 170, 2-185D, 190, 68 D-21 11, 72-220, 7000,7030, F-2 G,w/5 Heads,L-2 G, 330 No-Till
MACK ![]() Orange Level ![]() Joined: 17 Nov 2009 Points: 7664 |
There is a bolt kit to replace the rivits. MACK
CTuckerNWIL ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: NW Illinois Points: 22825 |
Sounds like something that needs immediate attention. It can get real messy and probably $$$ if things start coming undone in the differential.
Post Reply ![]() |
