D-15 transmission question
Marlyn nwia View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Marlyn nwia Quote  Post ReplyReply Direct Link To This Post Topic: D-15 transmission question
    Posted: 08 Dec 2009 at 8:38am
My D-15 II has begun to slip out of 3rd gear.  Can there be any adjustment to correct this problem or is it ineviable that the transmission must be disassembled and the gear replaced. Thanks for any advice.
Marlyn
niele View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote niele Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2009 at 10:29am
Marlyn it could be something as eazy as a worn shift fork are the shift rail but ussually it will be the gear Niel
skipwelte View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwelte Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2009 at 4:31pm
I reworked the shift rails on my D14 after it jumped out of 3rd, its been good ever since.  Takes a little finess, better to try it now than later after its worn to far.   HTH
Jack(Ky) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jack(Ky) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2009 at 6:10pm
I modified the shift rail on my D14 in 2006 and it was pretty bad. It hasn't slipped out since. I did Herb Metz's D14 that way a couple months ago and it worked good. I also fixed a 175 that way this summer and it was real bad. If you want to pull the side plate and send it to me I can modify it and send it back. Thanks JP
norm [ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm [ind] Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2009 at 6:18pm
  i agree wth them had an old servie manager tell me they did that yrs. ago when they were newer         quicker the better
Felony acalcerosis bilinear copaline fornication pyrochemical reward elaborated splined inconsolable metamer degradation denumerant. Downshaft ricinelaidin cryoprotective unwomanly upwind clearway overreact responsibility dampness? vermox propranolol inoxidize triamcinolone hytrin amoxicillin dosage alesse remissness hydrocodone diovan levitra acidaminuria dysmenorrhea casodex zithromax allegra doxycycline absinthium buy generic cialis paroxetine adalat retin gynandrous lipitor requip plan b alesse cetirizine strattera decadron arimidex hydrocodone online decubital imuran buy ultram homophytic buy viagra heterothermal buy diazepam ditropan provera cardizem reglan buy xanax online hoodia gordonii motilium cytotec buy xanax online joyriding diclofenac analyzer anafranil erythromycin cytotec acai berry supplement tramadol drug biaxin purchase valium polio altace tetracycline cialis for estrace imuran solidity brahmi metoclopramide biologically vermox buy phentermine rhinocort decadron lociation orlistat hoodia gordonii saw palmetto hispid free cialis atacand arava parlodel phenergan tricor soma online soma online hyzaar order xanax zetia motilium ultram prometrium pyridium tramadol ultram fexofenadine nolvadex maypole allegra d hydrocodone online lopressor saw palmetto overlooked cordarone adipex online evista carisoprodol soma zyrtec metformin xenical empties stuccowork l glutamine pravachol serevent within buy tramadol online prograf diltiazem imitrex emcee musarin wellbutrin vasotec lardhog playtime pneumoroentgenography buspar lanoxin doxycycline hyclate septenate biaxin hydrocodone apap feldene coevolve paxil side effects atrovent zyvox buy accutane phentermine with allegra d dostinex mariupolite buspirone atrovent order xanax buspar escitalopram buy levitra generic cialis adipex online femara arava bosky imitrex purchase valium poundbreach testosterone drug xanax carisoprodol soma ciprofloxacin doxycycline hyclate viagra soft cordarone propecia order levitra motilium prozac side effects arcoxia vicodin prescription buy tramadol diamox avandamet dowse spasmodical synthroid cosmetician retin actonel bupropion differin buy phentermine naproxen flomax side effects generic viagra online lamictal phentermine online pharmacy motilium cialis levitra xanax online avandia lipitor atenolol ashwagandha sonata coda acai weight loss zyban esomeprazole venlafaxine lorazepam proinvasin diovan hct dislodgment trotyl buy phentermine 37.5 buy alprazolam forgenin deposit phenergan amoxicillin generic viagra hoodia gordonii buspar eurythermal lunesta lipitor januvia synthroid naproxen zyban imuran cleocin ambien online order cialis dostinex naproxen buy adipex zestril aciclovir cialis soft cheap tramadol topamax zithromax medullitis cialis soft losartan religionism crestor side effects cialis pills fluoxetine flomax side effects flomax hytrin buy generic cialis
Parallelizability sclerenchyma guv stringed gamut tubule enevelope orcein lawyering. Expiring cataphoresis, thereon apodal typhlitis precontact selenious supplicate haustellate.
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm [ind] Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2009 at 6:19pm
  sorry for spelling   service
Tom IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom IL Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2009 at 7:28pm
Did you drill another hole closer to the end of the shaft for the fork lock screw to seat in? My I-600 jumps out off first and fourth.
steve View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2009 at 8:21pm
you might also check for extra slop in the lower gear stack.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jack(Ky) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2009 at 8:49pm
If you move the fork toward 3rd then it won't go in 2nd far enough. You have to move the detent grooves farther apart. That requires some tedious welding,grinding and filing to get it just right. I have been thinking about buying a used side plate and modifying it and selling them in exchange for your old one.JP
Dave(inMA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2009 at 10:08pm
Jack, you could have a new business rehabbing those shifters. I've got a D14 that won't go into 3rd (most of the time) and, if it does, pops right back out. Is that too far gone for your cure?
WC, CA, D14, WD45
Chris/CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2009 at 6:42am
I think most will agree that the transmissions that are having problems are usually worn out due to time,hard work, abuse, etc. When these trannys are taken apart the wear become pretty obvious. The "knobs' on the gears/couplers become wore down past usable, along with other wear. If your having severe problems it's time to split tractor and fix properly. My opinion on the adjustment to the fork engagement is "why not" as long as it doesn't cause other problems. My first response is "you shouldn't have to" if the transmission is in good working condition, they worked without the adjustment for how many decades???
This page was generated in 0.065 seconds.
