6080 pulling a planter?
ACFarmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACFarmer Quote  Post ReplyReply Direct Link To This Post Topic: 6080 pulling a planter?
    Posted: 02 Apr 2012 at 10:39am
Anybody have any idea if a 6080 fwa will pull a 6 row planter with splitter units? Tractor runs good and has like new tires all the way around but no duals. I have some decent hills but those fields are in no-till. Need to figure out if I can use the 6080 or I need to dig the old 190 series 3 out of the barn and use it. Borrowed a 7050 to pull the planter last year because i got it late.
Making a living farming with and working on Allis Equipment
Dean/MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dean/MN Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2012 at 10:47am
We used to pull a 6 row with a D17 with no problems in hills. We now pull a 16 row with an 8030 FWA. You should be fine with the 6080 FWA.
HD16,917H,185,7050,8030FWA,8050FWA
DanD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanD Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2012 at 11:47am
I would bet that a 6080 FWA would outpull a 190XT anyway in those conditions.
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2012 at 12:29pm
Yes it will. I used a 2WD model years ago to do it. Worked better with duals but it worked OK with singles
Charlie
StewartMD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote StewartMD Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2012 at 1:08pm
I'd have to agree with Dan.  A FWA 6080 will outpull a 190xt.  You should be fine.
8030, 8010, 220, 185, 160, D-17, WD, Unstyled WC, CA, G, 20-35, Gleaner E
This page was generated in 0.031 seconds.
