190 questions
prospolaris View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote prospolaris Quote  Post ReplyReply Direct Link To This Post Topic: 190 questions
    Posted: 01 Apr 2012 at 8:37pm
I see traction boosters for d17 and below. Does any one make one fo the 190 xt. Also looking for a water temp gauge. Also looking for a new air filter buy agcos is like 117 . Didn't know if fram or someone made one. Looking to San last in 2 weeks. Is there anything g that needs to not be touched. Of course not doing Turbo starter and alter. But is it safe on hydro valve bodies and such? Any info helps
Post Options Post Options   Thanks (0) Thanks(0)   Quote prospolaris Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2012 at 7:33pm
Bump
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2012 at 8:06pm
AdamA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AdamA Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2012 at 9:11pm
Ok I"ll take a stab at this; think your looking for a traction booster GAUGE,but not sure who has them availible for the 190xt maybe one for a d17 would work? Also air filters are made by several other companies most any parts store has an ag book and can look them up,Baldwin numbers are gas engines:PA1667-FN diesel engines S/N up to 13213:PA1636-FN, S/N 13213-up:PA1919-FN.
 Also I THINK you meant SANDBLASTING your tractor soon? if so I wouldn't get too carried away around the hyd valves and such, would stick mostly too large areas of sheetmetal/frame.
57'D-17,78'185,83'6080,76'7040,84'8030 FWA.02'Dodge cummins
