7060 Spindle Arms |
Post Reply ![]() |
7060 ![]() Orange Level ![]() ![]() Joined: 16 Sep 2009 Location: Missouri Points: 1148 |
![]() ![]() ![]() ![]() ![]() Posted: 31 Mar 2012 at 3:41pm |
Its been a while since Ive been on here, but I can't find anything about this in search anymore so Im going to ask again. I have a 7060 with worn spindle bushings. I ordered new bushings and washers, but need to get the steering arms off. I heated one up with a rosebud, but only had it red in a couple places since I was running out of oxygen. Then I dumped a couple 5 gallon buckets of water on it... and nothing. Not enough heat or did I do something wrong?
Carl(NWWI) ![]() Orange Level ![]() Joined: 13 Sep 2009 Location: NW WI Points: 954 |
get two torches with rosebuds to get er hot!! she needs to be glowing all around. then beat the heck outta with with a hammer, 4lbs hammer or so, hit on the back side/tie rod side, be prepared to hit it for a while, you can douce it in cold water, but when i did ours i didnt really notice a difference, key is to get it as hot as you can.
Carl
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21863 |
Remove the front tire/wheel. Remove the tie rod from the arm. Remove the axle knee from the axle and turn it upside down and reinstall it. Let the tractor down on a solid support and beat on it from above instead of underneath. I've seldom used any heat this way.
I beat on it a little, but was affraid of swelling the spindle shaft. If I flip the spindle over do I let the spindle set on something or just the axle tube and beat on the arm?
BobHnwO ![]() Orange Level ![]() ![]() Joined: 16 Sep 2009 Location: Jenera Ohio Points: 693 |
If the top of the shaft is mushroomed even a little it won't come off,BTDT,I used a belt sander around the top of the shaft.
YOU HAVE TO BEAT THE ARM OFF OF THE SPINDLE!!!!!!!!!!
Yeah, but what I was trying to understand was if you were resting the tractor weight on the axle or on the spindle that is upside down. I ended up resting it on the spindle to use the tractor weight with my hammer force. It moved it but im gonna need to go get some more oxygen.
MACK ![]() Orange Level ![]() Joined: 17 Nov 2009 Points: 7664 |
No don't set it on the spindel. Set support under axel housing. The shaft has a key and the key won't go through the bushing. MACK
Post Reply ![]() |
